Author Topic: Eurojet PCV fix  (Read 7797 times)
Offline jimmy-s3
Eurojet PCV fix
« on: June 09, 2011, 09:08:12 pm »
Has anyone done this or know where i can buy a similar product?
Re: Eurojet PCV fix
« Reply #1 on: June 09, 2011, 09:12:17 pm »
Dubtek on here sell them.
I have the BSH catch can kit.  Get quite alot of gunk over the miles.   I would sell my BSH catch can Kit to you but would need a replacement Pcv to fit 1st.  I want the more basic PCV fix without the catch can as I prefer the fit & forget aspect
**edit
Its BSH kits that Dubtek on here sell
Re: Eurojet PCV fix
« Reply #2 on: June 09, 2011, 09:18:18 pm »
Not sure if they still do them but I got one a couple of years ago from http://www.jbsautodesigns.co.uk/
Offline jimmy-s3
Re: Eurojet PCV fix
« Reply #3 on: June 09, 2011, 09:22:57 pm »
Id prefer a fix n forget too really.
My OEM PCV works fine but there is oil slightly leaking out where the ribbed hoses connect to the PCV, is this norm?
As for the oil, should it be getting down that hose towards the intake manifold? Surely fitting a non return valve into this hose will just collect oil then blast larger amounts into the intake manifold in one go rather than in small amounts?
Re: Eurojet PCV fix
« Reply #4 on: June 09, 2011, 09:35:07 pm »
For fit and forget I suggest you get the bsh revamp kit.
http://www.bshspeedshop.com/bshstore/products/BSH-2.0T-FSI-PCV-Revamp.html
Offline jimmy-s3
Re: Eurojet PCV fix
« Reply #5 on: June 09, 2011, 09:59:10 pm »
What about the oil seeping into the breathers and into the intake manifold?
Re: Eurojet PCV fix
« Reply #6 on: June 09, 2011, 10:09:14 pm »
With the revamp kit, the the pvc mechanism as well as the ribbed tubing from the pcv to the intake manifold is eliminated. You get a metal cap to block off the intake manifold port where the tubing inserted and a channeled metal plate to cover where the pcv was removed.
It's really quite a neat upgrade.
Offline jimmy-s3
Re: Eurojet PCV fix
« Reply #7 on: June 09, 2011, 10:14:32 pm »
what im asking tho is, what happens to the oil when it seeps into the intake manifold?
h4rdy
Re: Eurojet PCV fix
« Reply #8 on: June 09, 2011, 10:15:16 pm »
Just bought one from Ben on here at DUBTEK.
I nearly bought a catch can but just know I would forget to empty it and is it a stage too far?
I will let you know if its any good.
h4rdy
Re: Eurojet PCV fix
« Reply #9 on: June 09, 2011, 10:16:16 pm »
You mean normally with a PCV?
I think it just gets atomised and burnt with the fuel?
Re: Eurojet PCV fix
« Reply #10 on: June 09, 2011, 10:17:08 pm »
Do the vapours stick on the intake valves??
h4rdy
Re: Eurojet PCV fix
« Reply #11 on: June 09, 2011, 10:24:15 pm »
Not sure but it might cause a problem on heavy modded cars that would be why race cars have catch cans.
Offline jimmy-s3
Re: Eurojet PCV fix
« Reply #12 on: June 09, 2011, 10:29:00 pm »
Looking at the BSH revamp kit, and reading some threads on the US mk5 forum, the breather thats left seems to connect to the rear PCV breather at the back of the engine cover? Unless im reading it wrong?
Re: Eurojet PCV fix
« Reply #13 on: June 09, 2011, 11:05:55 pm »
Yes that's correct. The rear pcv breather, if fitted, is just a check valve.
Offline jimmy-s3
Re: Eurojet PCV fix
« Reply #14 on: June 10, 2011, 07:00:14 am »
Does that mean you plug  off where the rear PVC connects into the turbo inlet pipe near the dv?
