Author Topic: engine cover/airbox.........  (Read 2435 times)
Offline WYTHIT
« on: June 09, 2011, 10:41:23 pm »
Im after a part number for the metal  brackets that mount off the cylinder head onto the rubber gromits that hold the mk5 gti airbox/engine cover on please.
Offline flyboy1976
Re: engine cover/airbox.........
« Reply #1 on: June 09, 2011, 10:42:04 pm »
you mean the bobbins?
Offline WYTHIT
« Reply #2 on: June 09, 2011, 10:47:37 pm »
bobbins lugs what ver call them :P
« Reply #3 on: June 09, 2011, 10:51:45 pm »
4x rubber engine cover things £2.23 each
1x pole that rubber engine cover things push onto £3.60 each
from SERE motors as found on Seatcupra.net
Dave Hawthorne very helpful guy
Offline big al
« Reply #4 on: June 10, 2011, 10:21:24 pm »
Don'r suppose you know if the plastic bit on the end that the bung fits onto is available seperately do you? mine has somehow worn down.
« Reply #5 on: June 10, 2011, 10:25:52 pm »
I cant think which bit you mean
Offline jimmy-s3
« Reply #6 on: June 11, 2011, 11:29:09 am »
The rubber 'thumb' shaped things that the airbox cover pushes and fixes to are called 'ball joints' and are £5 each from VW
Offline big al
« Reply #7 on: June 11, 2011, 01:32:52 pm »
Legend, have given a thankyou.
Is there a part number on them? car is at a garage at the moment so can't check.
Doesn't affect the engine cover, but would just like to sort them out properly.
Offline QD MBE
  • -Receive: 102
« Reply #8 on: June 11, 2011, 06:01:47 pm »
WHT 000 898 A is the ball end spigot that the rubber slides onto..
and 036 129 689 B is the stop buffer or Grommet in the air box cover.
