Author Topic: Where do you check Clutch fluid on my Golf GTI?  (Read 12258 times)
Offline billlikecar
« on: June 10, 2011, 04:45:54 am »
i do not know where check Clutch fluid on my Golf GTI?
any body ideas???/
 :drinking:
As a car engineer,i would like to share my experience with you and welcome to my blog:http://eobd2.over-blog.com/
Offline kevinm
  • -Receive: 25
  • No. 728
Re: Where do you check Clutch fluid on my Golf GTI?
« Reply #1 on: June 10, 2011, 09:27:32 am »
It's supplied from the brake fluid resevoir.
« Reply #2 on: June 10, 2011, 09:31:56 am »
So Brake & gear oil is shared?
Thank you
Offline kevinm
  • -Receive: 25
  • No. 728
« Reply #3 on: June 10, 2011, 11:04:30 am »
Thank you
No clutch and brake fluid is shared. Gearbox oil is separate.
« Reply #4 on: June 10, 2011, 11:06:44 am »
Aaaaah, thank you.
Didnt make sense when I thouht about it with brake fluid being topped up from the bulkhead resevoir and gear oil at the box.
Clutch oil is only? Dsg then
Offline gazbutS3
« Reply #5 on: June 10, 2011, 01:29:17 pm »
No the clutch fluid being referred to is the hydraulic fluid used to actuate the clutch mechanism, this fluid is shared with the brake fluid Mike :happy2:
« Reply #6 on: June 10, 2011, 02:02:09 pm »
Makes perfect sense, having a mong morning  :ashamed:  Wheere abouts on the gearbox could this fluid potentially leak from?
Thanks again
Offline alexperkins
  • -Receive: 99
« Reply #7 on: June 10, 2011, 02:06:31 pm »
Thanks again
Clutch master cylinder is a possibility
Offline gazbutS3
« Reply #8 on: June 10, 2011, 02:08:50 pm »
there is a connector at the gearbox where the pressure line joins the actuator/slave cylinder, I had a slight leak here that only became apparant on track days etc when the fluid got hotter, we changed the O ring and now its fine, saying that I haven't done a track day since  :laugh:
« Reply #9 on: June 10, 2011, 02:14:31 pm »
If my brake fluid is low will certainly be investigating said places.  If not could be driveshaft oil seals again  :sad1:
Offline alexperkins
  • -Receive: 99
« Reply #10 on: June 10, 2011, 02:16:00 pm »
Driveshaft oil seals are for gearbox oil mike and not the clutch hydraulic fluid  :happy2:
« Reply #11 on: June 10, 2011, 02:18:02 pm »
I know.  One has gone before  There's oil drops on bottom of my box and along my ARB.  Need a day off work to have a good look :(
Offline alexperkins
  • -Receive: 99
« Reply #12 on: June 10, 2011, 02:22:54 pm »
If its oil its likely to be gearbox. Brake fluid is more like water rather than oil and doesnt tend to stick to things like oil does
Offline billlikecar
« Reply #13 on: June 24, 2011, 12:47:05 pm »
wow cool and thanks for sharing ideas :signLOL:
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #14 on: June 27, 2011, 08:11:29 pm »
Don't mean to go off topic here but has anyone changed their manual gearbox oil?
