Author Topic: MAJOR FUEL PUMP PROBLEMS!!!!!!!!!!!!!!!!!!!!!  (Read 20220 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: MAJOR FUEL PUMP PROBLEMS!!!!!!!!!!!!!!!!!!!!!
« Reply #30 on: June 11, 2011, 08:48:43 am »
Yep if you wanted to go rubber pipe you'd need to swap fuel lines.
Stu...
Offline MJR
« Reply #31 on: June 11, 2011, 12:23:25 pm »
Took the pump to a garage/machine place this morning and sadly the sheered off bolt has wrecked the threads inside the pump  :sad1:
So have just ordered a new pump & bolts etc for the time being which should hopefully arrive on Tuesday, then hopefully have the car back running again.
Then sort it out properly at a later date when I get the chance, simply just need my car running normally again for wednesday until August time.
A big thanks to everyone that has commented/helped.
I will update you again once I hopefully get it sorted, cheers.
« Last Edit: June 11, 2011, 02:02:02 pm by MJR »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #32 on: June 11, 2011, 09:14:04 pm »
I guess the the reason it sheared and has damaged the threads is because you cross threaded it.
Stu...
h4rdy
« Reply #33 on: June 11, 2011, 09:48:46 pm »
Did you upgrade(?) to the rubber type with new lines?
If you want me to try and tap out the old pump and rebuild it let me know?
Glad it is sorted.
Offline edd666999
  • -Receive: 89
« Reply #34 on: June 11, 2011, 10:13:35 pm »
Glad it is sorted.
you cant just change to the other fuel pump without upgrading the fuel lines. £500 job
h4rdy
« Reply #35 on: June 11, 2011, 11:00:36 pm »
Thats what I meant but didn't know it would be that much as its only one line isn't it?
I am probably wrong aren't I.
All off the top of my head!
« Reply #36 on: June 11, 2011, 11:05:18 pm »
When I checked a couple of years ago I was quoted around £120 exclusive of vat to switch from banjo bolt to the bamboo fitting. That included all the fittings...
h4rdy
« Reply #37 on: June 11, 2011, 11:08:58 pm »
I thought so, I think you could probably get a second hand intake off of the bay for cheap and just rob the lines.
Offline MJR
« Reply #38 on: June 11, 2011, 11:40:54 pm »
No I have just ordered a new fuel pump and banjo bolt, which should arrive Tuesday & fingers crossed I fit it ok & should have no more issues.
I may look into changing to the bamboo fitting at a later stage when I have time etc
How easy is it to replace the line to the bamboo version or best to book it in with VW to do it?
Was browsing on E-Bay and seen this:
http://cgi.ebay.co.uk/MK5-VW-GOLF-2-0-GTI-HIGH-PRESSURE-FUEL-PUMP-SENSOR-/320685054108?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aaa51989c
That doesn't look like its for the Mk5 Golf or am I seeing it wrong?
« Last Edit: June 12, 2011, 12:24:43 am by MJR »
Offline MJR
« Reply #39 on: June 12, 2011, 11:42:49 am »
Was this quote from VW?
« Reply #40 on: June 12, 2011, 02:30:11 pm »
No, from Awesome...
I doubt that a vw dealer would willingly take on this work as it moves the car away fron it's original spec.
Offline MJR
« Reply #41 on: June 12, 2011, 10:25:40 pm »
No, from Awesome...
Ahrite, thanks.
My next step is fitting my new pump successfully when it hopefully arrives on tuesday, ready for going away on Wednesday.
Will look into maybe getting it changed to bamboo fitting at a later stage :) as its official:
I HATE THE BANJO BOLT FITTING!!!!!!!!!!!!!!!!
h4rdy
« Reply #42 on: June 12, 2011, 10:38:18 pm »
Bamboo is better as like I said you can check the cam follower very easily.
I would believe that VW changed it for your reason and the cam follower check?
Offline MJR
« Reply #43 on: June 12, 2011, 10:44:41 pm »
VW doing it?
I'll be fitting my new pump etc myself on Tuesday hopefully if they arrive & fingers crossed I don't fook it up this time.
Offline MJR
« Reply #44 on: June 14, 2011, 06:07:24 pm »
Got my new pump & bolts etc today.
Fitted them ok and car now seems to be running fine again, hopefully thats the last of this issue  :smiley:
Will be putting my AutoTech Internals HPFP + New Bolts up for sale soon when I get a chance, all the person needs to do is get the sheered off bolt out and they will have a bargain.
Thanks to everyone that helped with guidance, part numbers & calming me down lol
