Author Topic: Mk2 TT Lower Arms + Big Brake Kit  (Read 7795 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« on: June 10, 2011, 08:06:12 pm »
Who running this combo and did you have any issues with the ball joint being too close to the disc?
  • -Receive: 291
Re: Mk2 TT Lower Arms + Big Brake Kit
« Reply #1 on: June 10, 2011, 08:11:29 pm »
This would be entirely useful info. Which BBK did you have? Was it a VWR set up?
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #2 on: June 10, 2011, 08:18:37 pm »
I have TT arms but DaveB's nqsbbk but I know the problem you are referring to...
The ball join is very close to the disc and there is no heat shield for the bbk. This might cause the ball joint to suffer from head stoke. This is really crucial because it has rubber components which degrade after being subjected to great temperatures.
Is this the problem or just the spacing issue?
I am really curios to see what you find out. Hope there aren't any problems...  :drinking:
Offline Beddie
  • -Receive: 76
« Reply #3 on: June 10, 2011, 08:18:45 pm »
I remember Mike (TD) having problems with his standard lower arms and an AP BBK, iirc it was a fairly large disc set-up similar to the VWR one but only gave a few mm's clearance to the ball joint hence him getting his Alcons to get around the problem
Carbon Grey Edition 35 - Here
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: June 10, 2011, 08:37:03 pm »
The issue is it about 1mm into the disc (VWR 6 Pot), however KPM Racing (who are fitting these) have used this setup on a couple of their VW Cup cars before with the VWR brakes and had to make a slight cut on the edge of the balljoint to give a bit extra clearance but mine just won't fit  :confused:
Just wondering if there are different versions of the GTI hubs??
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #5 on: June 10, 2011, 08:43:32 pm »
Nope. Unless they changed the GTI hubs with S3 hubs.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: June 10, 2011, 08:44:38 pm »
Nope there are 100% the original GTI hubs on the car.
Offline Beddie
  • -Receive: 76
« Reply #7 on: June 10, 2011, 08:51:27 pm »
Only thing i could think is that you have a slightly different disc set up to the current VWR ones? Did they use the first gen (project Mu) on yours Steve? Could be the 'Offset' on the disc bell?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #8 on: June 10, 2011, 08:53:39 pm »
Nope both using the newer 6 pot AP Caparo brakes  :confused:
Offline Beddie
  • -Receive: 76
« Reply #9 on: June 10, 2011, 09:00:49 pm »
Hmmm weird one for sure!  :confused:
« Reply #10 on: June 10, 2011, 09:08:38 pm »
Any pics Steve?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: June 10, 2011, 09:17:00 pm »
Nope will be popping back to the workshop with more parts tomorrow morning so will try to grab some then if it's still on the ramps  :happy2:
« Reply #12 on: June 10, 2011, 09:34:22 pm »
Would having adjustable top mounts make any difference for clearance ?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #13 on: June 10, 2011, 09:37:55 pm »
Not to the level of difference I saw today I wouldn't have thought.
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: June 11, 2011, 11:32:50 am »
Have the cup cars not got the kw bent coilovers which give loads of camber. This will give them a bit more clearance but not much. Try and get some pics up.
Follow AKS tuning on Facebook
