Author Topic: Mk2 TT Lower Arms + Big Brake Kit  (Read 7620 times)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Mk2 TT Lower Arms + Big Brake Kit
« Reply #30 on: June 11, 2011, 10:46:22 pm »
I don't think there are any differences in dimensions between Golf/A3 bearings
and S3/TT bearings, just a completely machined surface.
Also my track width doesn't increase with the S3 (3C0...) hubs (fortunately).
No doubt without any dust cover the rotor will cook the ball joint which
has an inner plastic lining and is filled with grease. This will shorten it's life
significiently.
I'd recommend to protect the ball joint by bending a small piece of sheet
metal on it.
Bend yellow parts 90° to protect the ball joint and the green around the the steering rod.
"You get what you pay for."
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #31 on: June 11, 2011, 10:56:18 pm »
The centres for the 4 mounting bolts are the same, they're all iron no ali elements, they're all driven, unless the splines are different. So maybe the only thing that can change is the offset.
Maybe the car had some lowish ET wheels on at some point and some genius decided it would work......
Offline QD MBE
  • -Receive: 102
« Reply #32 on: June 11, 2011, 11:30:29 pm »
Disc was looking central according to Mr P.
Strange..........
  • Trader - 2014
  • -Receive: 130
« Reply #33 on: June 12, 2011, 12:05:13 am »
Audi offsets can be a little freaky though Dave, take for example the TTRS rears, assumed to be S3 rears....actually exactly 10mm taller than S3's and the carriers very different.
Theres 10mm sort of floating between the different platforms with a combination of hubs to "wheel bearing housings"
Im far from saying Im right, just a possible freaky answer to a freaky problem..you're right though very strange
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #34 on: June 14, 2011, 08:15:02 am »
Well the mystery continues, back on the original arms with new GTI balljoints (old ones had seized so had to be cut off) and these are too close to the disc  :confused:
To the point the right hand one touches the disc on full left hand lock, anyone got any more ideas ?
« Last Edit: June 14, 2011, 10:25:38 am by SteveP »
« Reply #35 on: June 14, 2011, 10:20:27 am »
What did Mat say had been changed on the front end of the car?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #36 on: June 14, 2011, 10:25:09 am »
Only bushes.
graphys
« Reply #37 on: June 14, 2011, 02:43:30 pm »
Hi Steve;
I can't register Mk5GolfGTI.com and sent private message. I have a Golf mk6 but car haven't ESP. I want make TPMS system. It's working my Golf?
« Reply #38 on: June 14, 2011, 03:15:05 pm »
Only bushes.
:confused: strange as the brakes had been built around my car and your car,infact i have a pic on my phone of your car when it had the very first ever caliper and disc setup put on it on my phone. keep us up to date  :smiley:
rcaero
« Reply #39 on: July 28, 2011, 08:03:03 pm »
Does anyone have an update on this? As I just accquired a set of used TTRS lower arms, and was planning on fitting it together with the Forge BBK.
But now that I read about these issues, perhaps it would be advisable to stick to the BBK only?  Thanks
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #40 on: July 29, 2011, 08:03:17 am »
With a lot of other BBK's you might be fine, but without knowing how far inwards the disc sits on the Forge kit I can't confirm. :happy2:
Offline Ree
« Reply #41 on: July 29, 2011, 08:18:05 am »
Hi Steve sorry for replying in this section, I am interesting in your folding mirrors but as a new member I can't reply in the sale section or pm you.
Wanted to know as you are advertising fitting to, where abouts are you.
I have 56 3dr r32, if you could drop me a pm please, thanks again.
Offline Carrera2RS
« Reply #42 on: August 02, 2011, 07:18:41 pm »
I found the bottom TT MKII ball joint to touch VWR brakes, Seems the sizes from the hub mounting face plate to the inner disc face are 50mm VWR, 47mm AP and 42.3 Alcon 6-pot and 4-Pot
Looking at a few pictures I think the TT joint sits at a 'better angle' with the strut, but this means the bottom corner protrudes out more. I might try and see how much excess meat there is on the joint to get extra clearance from grinding. Any ideas
I think the AP kit will fit but have yet to measure exact clearance, If I knew the fig fro the stock disc I could measure the stock clearance ?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #43 on: August 02, 2011, 07:54:59 pm »
If it was like mine then there isn't enough "meat" to grind back on the TT ball joints to make them fit   :sad1:
Offline Carrera2RS
« Reply #44 on: August 02, 2011, 09:24:42 pm »
Bugger, it seems odd as the ball joint is attached to the same point it is only the casing that is different and the angle of this must be where it goes wrong, I wish I had measured more accurately. The AP kit I am sure will fit as I have picture of this with the backplate fitted, so we are only talking 3mm (50-47)
Did you try the VWR kit ? and grind ?
