Author Topic: What did you and your MKV do today?  (Read 2800995 times)
Offline golfmck1980
« Reply #10065 on: January 28, 2017, 09:51:58 am »
Finally getting round to sticking a new head unit in the car cant stick that rcd 300 anymore
Edition 30 num 859
Offline Kai96
« Reply #10066 on: January 28, 2017, 12:17:33 pm »
Cam follower and DV done (How bad is it ?) . My DV was defo shot to bits as the car feels 10x smoother now and a lot more responsive which is a plus.
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #10067 on: January 28, 2017, 12:35:49 pm »
That doesn't look too bad at all, do you know if it was ever done before and how many miles?
« Reply #10068 on: January 28, 2017, 06:39:33 pm »
Annual crud clearing from behind the arch liner.  We know how MK5s love to rust, so prevention is better than the cure  :smiley:
The first time I did this after getting the car, the crud was half way up the wing, but not so bad after a year....
Back to how it should be  :smiley:  And yeah, that is a new wing under warranty.  VW don't paint the underside of it at the factory, tight barstewardss!
« Last Edit: January 28, 2017, 06:42:22 pm by Pudding »
Offline 6waysforward
  • Boost junkie
« Reply #10069 on: January 28, 2017, 06:56:46 pm »
I've never thought of doing this before. Dam, another job on the list
Tornado Red GTI DSG
Offline Kai96
« Reply #10070 on: January 28, 2017, 09:02:28 pm »
No clue if its been done before & currently @ 68k
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #10071 on: January 28, 2017, 09:34:50 pm »
Mine looked the same, similar mileage
willni
« Reply #10072 on: January 29, 2017, 09:12:01 am »
Cleaned my engine "bae"
http://imgur.com/a/ALWUK
Offline spwd
  • Hello I'm Steve.
« Reply #10073 on: January 29, 2017, 02:16:55 pm »
Wow, very clean :congrats:
Offline K9
  • VW LifeStyle
« Reply #10074 on: January 29, 2017, 03:19:00 pm »
flushed old brake fluids out and new in + aired the system. Much better feeling in the clutch now.
Offline flashp
  • -Receive: 65
« Reply #10075 on: January 29, 2017, 04:18:05 pm »
Somebody else who needs to do this!  :thinking:
Gone but not forgotten :-)
4ndy
« Reply #10076 on: January 29, 2017, 06:08:53 pm »
The reason mud flaps belong in the bin :happy2:
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #10077 on: January 29, 2017, 07:06:11 pm »
I remember when I took the plastic arch liners off my mk4 and the amount of mud behind there was unreal. Was 2 full dustpan and brush worth.
I am going to do the ed30 in a week or so when I get bored. Anyone know if removing the bit of sponge behind the arch is a good idea too? I've heard this aids in a lot of the rusty arches cases.
« Reply #10078 on: January 30, 2017, 11:28:50 am »
Yeah you just need to cut back the foam block an inch or so where it touches the arch's folded lip.  Don't need to remove the whole thing if you don't want to.
Yeah only do it if you're bored.  I did it whilst the car was on stands doing other stuff  :smiley:
My MK4 had shed loads back there too.  It must be the rubbish that falls down the scuttle drain holes?  I can't see how else that stuff can get behind there?  It was the soggy 'mud' that surprised me.  Not sure how that gets in there, but it stays wet for ages, which promotes rust.
Offline P3T3R
  • 05 GTI, R-Tech stage 1
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,82245.0.html
« Reply #10079 on: January 30, 2017, 07:18:52 pm »
Not happy, just pulled out of the sh*tty works car park and the pressure sensor beeps at me, so stopped and a quick check revealed a screw in the sidewall of my rear tyre (eagle F1) that still had about 5mm left. So straight to the nearest tyre place that wasn't kiwi fit.
