Author Topic: What did you and your MKV do today?  (Read 2798287 times)
4ndy
« Reply #10155 on: February 19, 2017, 09:08:05 pm »
Used pronator to clean door hinges then smothered in lithium  grease.
Offline GYG30
« Reply #10156 on: February 19, 2017, 09:48:08 pm »
Got sheep s**t over it in car park at Dubfreeze Stafford
Offline The Red Warrior
« Reply #10157 on: February 20, 2017, 05:34:44 am »
Finally fitted full led brake light, reverse and fog bulbs. Enabled emergency brake light flashing in vcds. Tried out some new COB LED side lights, so much brighter than standard SMD leds but run so fecking hot I had to get them out and stick with the bold sport ones!!
Not on the car but for the car in readiness for the summer and detailing... little project on the go...am making a diy sun gun to check for paint swirls and the like.
Enabled emergency brake light flashing in vcds. I've done this too, but apparently it's working. Have you have someone confirm that yours actually are?
« Reply #10158 on: February 20, 2017, 05:37:44 am »
@MPS That video is hilarious. The advertising standards committee over here would go mental if that was on TV here.
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #10159 on: February 20, 2017, 02:01:19 pm »
was wetting myself in work at those commercials!
« Reply #10160 on: February 20, 2017, 03:24:58 pm »
Got an MDI kit installed to go with the recently acquired RCD510, and put in a new glove box to get rid of the old OEM Nokia cradle.
Big thanks to @Pudding for providing the MDI kit.
Finally, no more messing about with CDs!
Nice  :smiley:
Glad it's gone to a good home!
Offline Christiank
  • -Receive: 39
« Reply #10161 on: February 21, 2017, 05:18:54 pm »
Finaly got the time today and the weather was to it - So I splitted the interior out to repair my auxiliary heater.
Had a fault saying it was defect, so thought I would give it a go and solder some parts.
At start the output was around 200-350w.
after 1 attempt to repair the output came up to about 700w - but still the fault code in vcds.
did take another try and finaly 990-1000w output and no fault code :D
Offline theminty1
« Reply #10162 on: February 21, 2017, 05:30:33 pm »
Well done Christiank, but i guess your car is Left hand drive as to do it in a rhd car is a pig. It makes a big difference though :)
I had a 2nd hand one fitted as nothing looked wrong with mine.
140 BKD GT TDi  5dr
Offline Christiank
  • -Receive: 39
« Reply #10163 on: February 21, 2017, 05:42:10 pm »
Thanks mate
Yeah it's LHD - I live in Denmark :)
Offline JamieKirk95
« Reply #10164 on: February 22, 2017, 10:41:21 pm »
Changed the grab handles and switches
Headlight Switch
First off, in the off position push the switch inwards
Twist to the automatic lights position
Then simply pull out and unclip the electrical connecter
Old vs. New
Fitted
Drivers Side
Before
Comparison
Disconnect switches
New Switches
After
Passenger Side
To start we used the trim removal tool to separate the two plastic pieces, the top one is held in by two t30 screws, we removed these and then thought the handle would then come away...
However, the handle is also held in by two screws at the back so it meant we would have to remove the door card to gain access.
The replacement
We then took the door card off, the door card itself is held in place by 4 t20 screws one on the side and three along the bottom
We then lifted up the door card
I then located the two t20 screws to undo, the handle then came away and we reversed the process
Door card back on
After
Comparison
Fuel Switch
I don't have many photos of this as it was a right pig of a job to do:lol:
Before
Comparison
Jamie
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #10165 on: February 22, 2017, 11:06:17 pm »
Nice one Jamie  :happy2:
« Reply #10166 on: February 23, 2017, 05:57:16 am »
 :worthless:
Oh, wait. There may have been some  :signLOL:
Offline dools225
« Reply #10167 on: February 23, 2017, 06:27:19 am »
Nice job @jamiekirk95  :happy2:
Did the new grabs come with the mirror & window switches? Mine are pretty mullered so on my list to replace!
4ndy
« Reply #10168 on: February 23, 2017, 06:33:29 am »
:worthless:
Pics suspended due to lack of SD128gb card space :signLOL:    Certainly tidier  than before :happy2:
Offline leebes
  • When's the next track day?
  • My Ride: 2007 Mk5 Gti (Reflex Silver)
« Reply #10169 on: February 23, 2017, 08:27:06 am »
Pro Races back on for the 'better weather' and track day in a couple of weeks  :happy2:
« Last Edit: February 23, 2017, 08:29:04 am by leebes »
