Author Topic: What did you and your MKV do today?  (Read 2757010 times)
« Reply #10665 on: August 09, 2017, 11:46:11 am »
Nice!  So did mine until I fitted a sports cat  :grin:
What have I done lately...... fitted a VWR intake, load of rubbish, so took it off again.  Did a compression check and got 14 bar across all 4 cylinders, so I'm happy the engine is nice and healthy for a 113K old timer  :smiley:
The owners manual and the internet are both useless when it comes to finding the fuses for the ECU and fuel pump, so anyone else wanting to do a comp test, simply pull relays 100 and 167.  They are in the engine bay fuse box.  You need to pull those to stop fuel being sprayed in when cranking.
« Last Edit: August 09, 2017, 11:48:13 am by Pudding »
Offline Ripstop
« Reply #10666 on: August 09, 2017, 12:11:00 pm »
Bilstein B4's fitted and a brake fluid change at AKS... yeah yeah I know nothing special but boy I didn't realise how tired the old suspension had got after 105k miles. I drove home a with a big grin on my face.. the car was just so much smoother and tighter on the road. It also got rid of my small lump hammer monkey on the front drivers side strut.... the knocking noise has totally disappeared!!!  :happy2:
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
« Reply #10667 on: August 09, 2017, 12:17:39 pm »
Result  :happy2:
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #10668 on: August 09, 2017, 12:37:38 pm »
Do they change the ride height much? Any pics?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10669 on: August 09, 2017, 12:50:23 pm »
Dampers don't change ride height. It's the springs. :wink:
Also Bilstein B4 won't be as sporty as OEM dampers. OEM dampers should be more like Bilstein B6.
Offline Rossimac
  • -Given: 78
« Reply #10670 on: August 09, 2017, 01:06:25 pm »
Gotcha! With mine on 136k miles now, I think I don't even know what a "good" suspension feels like. Bought it at 95k miles.
Offline Ripstop
« Reply #10671 on: August 09, 2017, 01:13:15 pm »
The ride height shouldn't change with standard springs and sorry didn't take any photo's.... was pissing with rain but I also need to mention that I have already fitted a set of H&R springs on it from one of my previous visits due to a snapped front spring and two rear's with the tops broken off. I can get some photo's of the current drop height later when its stops raining if you want. The drop I think from memory was about 20-25 mm and the wheels sit perfectly in the arches.. well I think so anyway  :smiley:
I did think the B4's were the OEM equivalent and the B6's were the "harder" sport option. But anyway doesn't matter as for me they are just right.
Offline OEM+ DUB
« Reply #10672 on: August 09, 2017, 01:23:49 pm »
B4 dampers are the OEM equivalent. Generally speaking, B6 are uprated for standard height set ups and B8 dampers are uprated for lowered set ups. B6 and B8 both have a thicker diameter piston for increased strength/stability under load and "upside down" internal construction if I remember correctly from my research (I went with B8s and VWR springs).
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10673 on: August 09, 2017, 01:28:02 pm »
B4 dampers are the OEM equivalent for normal suspensions. GTI have a sport suspension. For me the B4 Sport dampers will be more like the sport suspension that GT Sport versions like my 1.9 TDI GT Sport had from factory.
Offline OEM+ DUB
« Reply #10674 on: August 09, 2017, 01:43:22 pm »
Bilstein have specific part numbers for B4 fitment for the GTI with both front and rear gas pressurised.  These have exactly the same piston diameter and construction as the standard factory fit dampers. The B6s are far more firmer than standard or B4 dampers.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10675 on: August 09, 2017, 01:52:12 pm »
Ok, thanks for the explanation! :drinking:
« Reply #10676 on: August 14, 2017, 10:41:48 am »
If you guys get any strange hesitancy, rough idle, sluggishness until boost kicked in, jolting when coming off the throttle, surging in the lower gears, unexplained acceleration coming off the throttle...... it's worth checking your cam sensor.
My ED30 had all of that and my sensor had years of swarf stuck to it, which was corrupting/blocking the signal.   Swapped it out (£38 from the stealer) and it's fixed all of that  :happy2:   The ECU never fault coded it, so just goes to show you can't always rely on VCDS for fault finding.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10677 on: August 14, 2017, 11:02:31 am »
Good info @Pudding! One more detail to be aware of. :drinking:
« Reply #10678 on: August 14, 2017, 11:12:46 am »
The jolting coming off the throttle was making me want to set fire to the car, so was worth doing it just for that!
Offline GTIEagles
« Reply #10679 on: August 14, 2017, 12:03:51 pm »
Cleaned it... 2nd time this year  :ashamed:
