Author Topic: What did you and your MKV do today?  (Read 2786154 times)
Offline Christiank
  • -Receive: 39
« Reply #10860 on: November 13, 2017, 01:13:37 pm »
Good work!  I tried to install the puddle lights in mine but was a complete fail.  After the wiring and coding......absolutely nothing  :grin:
Shouldn't be that much of a problem to fit the ligths?
How did you do it since it never worked? :)
« Reply #10861 on: November 13, 2017, 02:22:39 pm »
You would think so, but nope, didn't work.
I followed this guide like everyone else!  https://www.my-gti.com/2240/adding-door-warning-lights-to-the-volkswagen-golf-and-jetta-rear
Offline Christiank
  • -Receive: 39
« Reply #10862 on: November 13, 2017, 02:38:42 pm »
So your car is with Gen 1-2 door modules, so +12v is pin1 and ground from pin 2 or 4.
« Reply #10863 on: November 13, 2017, 02:52:56 pm »
Mine's a 2007, so could be.  I don't really care about the lights tbh, I just attempted it when I was bored one afternoon  :grin:    Might have another go in the summer!
Offline Christiank
  • -Receive: 39
« Reply #10864 on: November 14, 2017, 11:23:07 am »
Installed my new custon made dials in my cluster :) Think the result is awesome! :)
Offline The Red Warrior
« Reply #10865 on: November 15, 2017, 08:28:48 am »
Wow @Christiank
Those look awesome. I'd like to do something similar myself but I see you've already retrofitted a Mk6 dash as well.
I guess I'm after the scirocco 3D clocks
Offline Christiank
  • -Receive: 39
« Reply #10866 on: November 15, 2017, 02:01:27 pm »
Wow @Christiank
Thanks mate.
Yeah I've got the Mk6 dashboard and centre console fitted in my Mk5.
Try search out a facelifted scirocco cluster that has the "3d" housing and then just use the front from it to your current cluster or the 3d/color one you're getting :)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #10867 on: November 16, 2017, 09:21:47 am »
Went out to cut the studs of my hpfp stud kit so future cam follower replacements will be easier when removing the hpfp. Cut 6mm off, got them re-chamfered, and installed using a homemade stud-driver.
Then I decided to look at the APR hpfp piston seals and pulled out the piston. I saw slivers of rubber just inside the hole with the piston removed. I took the seal out and it was in bad shape. I found a VITON o-ring that will work until I order and receive the proper type quad-rings: https://www.amazon.com/Sterling-Seal-XP75VIT012X10-Viton-Black/dp/B01F0HFH6E/ref=sr_1_11?s=industrial&ie=UTF8&qid=1510820276&sr=1-11&keywords=viton+quad-ring
« Last Edit: November 16, 2017, 09:24:41 am by ROH ECHT »
« Reply #10868 on: November 16, 2017, 11:50:42 am »
Got any more pics / info on that process?  Just wondering if I should do the same with my Loba as it's done quite a lot of miles now.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #10869 on: November 16, 2017, 07:52:52 pm »
No, no pics. I have 83k miles on my APR HPFP kit...and, why I was just curious.
LOBA looks to use the oem nut collar like Autotech does. They give you a larger pump cylinder, a spring, and the dual sized piston in order to reuse the oem nut and end cap. Their piston has two sections of different diameters in order to do so. The smaller goes into the oem nut collar: http://www.loba-motorsport.com/img/img-07.jpg
I would not recommend removing the seal before knowing what to replace it with, or even if you can. For example, Autotech and LOBA uses the oem nut collar and it has a press-in seal inside. Integrated Eng. and APR make their own. So all seals inside may differ. It may get damaged attempting to remove it and then you're F'd. I realized that before beginning and decided F-it, I'm going for it. I used one form my hook and pick set to remove the seal. It was shredded badly, so I temporarily installed a VITON o-ring size-012 (3/8" ID - 1/2" OD). Used small wooden dowels to install it into the groove inside the nut-collar where the piston goes back into. New VITON quad-ring ordered and will install when received.
APR confirmed the seal material today, saying "Flouroelastomer Polymer"
After doing more measuring, seal type determining, and ring seal reading...I mean, a ton of reading. Especially Chapter 5: https://www.parker.com/literature/O-Ring%20Division%20Literature/ORD%205700%20Parker_O-Ring_Handbook.pdf
...I found, if needed for an APR HPFP(all brands differ as they are custom made); use VITON 75D quad-ring: https://www.amazon.com/Sterling-Seal-XP75VIT012X10-Viton-Black/dp/B01F0HFH6E/ref=sr_1_11?s=industrial&ie=UTF8&qid=1510820276&sr=1-11&keywords=viton+quad-ring
Size-012 Quad-Ring dimensions; sec;1.78 ID;9.25 OD;12.81
This is a 2.5tfsi by APR, but it's the best image and angle showing the seal I speak of and where it goes...seal #1 goes inside position #2:
« Last Edit: November 16, 2017, 08:29:08 pm by ROH ECHT »
Offline horsemeat
« Reply #10870 on: November 20, 2017, 01:43:50 pm »
Another 5k, another oil change.  :innocent:
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« Reply #10871 on: November 20, 2017, 08:14:07 pm »
A good clean and took some photos, build thread coming soon!
Offline Ant b
« Reply #10872 on: November 21, 2017, 05:42:59 pm »
Wired in door lights,and refitted my resprayed fuel button surround and new button
red mk5 golf gti ks05 fak,ram air intake,3” downpipe/decat,dv+,bcs rev ll exhaust stage 1 remap.coilovers,whiteline rarb and depo projectors,
Edition 30 front splitter,r32/gti rear,r32 side skirts
Soon to be r tech stage 2
Offline Octoparrot
  • -Receive: 102
« Reply #10873 on: November 21, 2017, 07:04:31 pm »
130k Oil and filter change.
Offline Ads22
« Reply #10874 on: November 22, 2017, 08:15:55 pm »
Not quite today but took mine to the local Pistonheads Sunday Service this weekend at Denbies Vinyard in Surrey. A nice variety of cars and good setting. Recommend it next time it comes round. I was the only MK5 there from the looks of it!
DSC_8828 by Adam Gagliani,
DSC_8800 by Adam Gagliani,
DSC_8844 by Adam Gagliani, on Flickr
DSC_8809 by Adam Gagliani, on Flickr
DSC_8813 by Adam Gagliani, on Flickr
