Author Topic: What did you and your MKV do today?  (Read 2786739 times)
Offline GPem3:16
« Reply #11010 on: February 20, 2018, 03:53:30 pm »
With all this talk of cleaning.....I ought to get the foamer out.
In other news I swapped the headrests over from front to back...looks sweet tbf.
Sent from my SM-G930F using Tapatalk
Offline GPem3:16
« Reply #11011 on: February 20, 2018, 03:53:38 pm »
« Reply #11012 on: February 20, 2018, 04:11:59 pm »
Wow, getting the foamer out 5 times  :grin:
Offline GPem3:16
« Reply #11013 on: February 20, 2018, 04:41:34 pm »
Ooops phone problems. My bad
Offline GPem3:16
« Reply #11014 on: February 20, 2018, 04:41:48 pm »
Offline GPem3:16
« Reply #11015 on: February 20, 2018, 04:42:28 pm »
Technical issues :laughingface.
Offline GPem3:16
« Reply #11016 on: February 20, 2018, 04:44:01 pm »
Wtf is with this sending multiple messages
Offline Nardoblue
« Reply #11017 on: February 20, 2018, 11:04:47 pm »
Cleaned it and the other toy
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11018 on: February 21, 2018, 09:56:45 am »
Love the GSX1100....1984? Back in 1980 those GSX1100's were the beasts to beat. My 1976 Kawasaki KZ900, with jets/intakes/exhaust/sprockets/lowered/stripped and cafe'd, had trouble with those and the Honda CBX 6 cyl. monsters.
My kz900 started out like...
...and ended up a lot like this 1000 with diff wheels and as much black as I could put on it...
« Last Edit: February 21, 2018, 10:25:33 am by ROH ECHT »
Offline Ads22
« Reply #11019 on: February 25, 2018, 04:21:49 pm »
Not much of a whiz with DIY but managed to hardwire dashcam
And then also fitted leather cover to my cloth armrest
« Last Edit: February 25, 2018, 04:24:10 pm by Ads22 »
Offline Christiank
  • -Receive: 39
« Reply #11020 on: February 25, 2018, 06:54:32 pm »
Manged to finaly get the wirering done for the active TMPS
Also retrofitted heated windshield washer jets, black mk6 golf headliner and pillar trims.
willni
« Reply #11021 on: February 25, 2018, 08:31:20 pm »
Advanced a bit with my Passat CC climate control retrofit (Copying @ChristianK ) waiting for the filler to dry to smooth it out fully
Offline Christiank
  • -Receive: 39
« Reply #11022 on: February 26, 2018, 04:58:43 am »
You're getting there mate! :D  :party:
Did you use the repo plast glue or did you end up with a solder iron?
willni
« Reply #11023 on: February 26, 2018, 11:16:51 am »
Tried the epoxy glue first but it didn’t work out didn’t harden fully (got to about 50% think it was the cold), so I needed up using a soldering iron and two pin nails and joining the two through a weld.
Now I’m just working on the edges to get them nice and straight.
Also did you have to cut two tabs off from the dash just above the two outter circles?
Offline Christiank
  • -Receive: 39
« Reply #11024 on: February 26, 2018, 04:15:59 pm »
I didn't cut anything at the dashboard, all were done to the frame :)
