Author Topic: What did you and your MKV do today?  (Read 2789218 times)
Offline Stupots
  • -Given: 18
« Reply #11115 on: May 09, 2018, 09:41:10 pm »
@neilw I got the Brembo TTS 340mm discs as advised by @Shoduchi
Really impressed with the coating on the vents and around the centre. I’ll put all the part number when I update the other thread, but the discs are part 09.9771.11
Stu
Offline neilw
« Reply #11116 on: May 10, 2018, 09:21:41 am »
Stu
Cool, thanks those were the ones I was going to get. Seen them for just over £100 for the set. Good to know they seem good
Edition30 #0002 R-Tech Stage2
« Reply #11117 on: May 10, 2018, 02:13:51 pm »
Good stuff Pot of stew, let me know how the pedal feels after they've bedded in.
I also have a set to go on (well, the Performance pack calipers and Clubsport S discs) but I've been lazy and I'm still torn about adding so much extra unsprung weight  :thinking:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11118 on: May 10, 2018, 09:59:37 pm »
OK...I will ask...do those pads actually meet the inner diameter of the disc surface? Because it appears there's quite a gap from the inner diameter of the disc surface and the inner edge of the pads. Quite possibly just the pic angle interfering I suppose.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11119 on: May 10, 2018, 11:44:55 pm »
Does this picture answer your question?
Offline Stupots
  • -Given: 18
« Reply #11120 on: May 11, 2018, 06:52:47 am »
I'd say i noticed about 5-7mm when fitting them. I'll post a pick when I have a wear mark.
Offline Ripstop
« Reply #11121 on: May 11, 2018, 10:51:14 am »
Eddie passed his MOT :happy2: Hooray!! New style MOT certificate... not sure I like it. :confused:
Two advisories with an uneven rear tyre wear NSR (usual Mk5 issue) and a small pinhole in the centre rear exhaust box.
Both will be attended to in next month or so.
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
« Reply #11122 on: May 11, 2018, 05:45:11 pm »
It must just be the picture as my 340mm setup has good pad coverage:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11123 on: May 12, 2018, 08:46:50 am »
No need really. I think it was a brief photo-illusion. I just looked again and what I saw yesterday is actually the radius bit on the center span of the carrier.  Yesterday it looked like I was seeing the disc through there but it is the carrier and not a hole. Yikes, blame my 56 yr old eyes.
Offline neilw
« Reply #11124 on: May 12, 2018, 05:39:30 pm »
Picked up some new bits courtesy of Mr @Bodyboarder81  :drinking:
1 hour later
Offline Bodyboarder81
  • -Given: 35
« Reply #11125 on: May 12, 2018, 05:49:59 pm »
All in perfect condition , as with all the other parts I’m selling  :happy2:
Hope you like the noises ! :driver:
Offline neilw
« Reply #11126 on: May 12, 2018, 06:14:31 pm »
Thanks, not trying it until tomorrow, but looking forward to the noises!
I got a hose clip from Motorworld, had to order a bigger one for the other end of the pipe. You were right about getting the pipe off the turbo, annoying!
Offline TheBALDpuma
« Reply #11127 on: May 13, 2018, 08:58:24 pm »
Gave mine a wash and wax today...
Going back to VW tomorrow. It had the abs recall work done a few weeks ago, and I got a call last week saying they need to do another update. It was the dealer that called. Anyone else had this?
Offline Ads22
« Reply #11128 on: May 13, 2018, 09:48:25 pm »
Took a trip to Cheddar Gorge and down some tasty Somerset roads
DSC_0941 by Adam Gagliani, on Flickr
DSC_0923 by Adam Gagliani, on Flickr
« Last Edit: May 13, 2018, 09:55:47 pm by Ads22 »
Offline golfmck1980
« Reply #11129 on: May 13, 2018, 11:01:12 pm »
Fitted some sound proofing today that was a pain in the arse
Edition 30 num 859
