Author Topic: What did you and your MKV do today?  (Read 2979927 times)
Offline willk86
« Reply #11145 on: May 21, 2018, 07:59:43 pm »
Been working through the engine, refreshing a lot of tired sensors........but last week I changed the MAP sensor being one of the last original sensors on the 2005 car.........no error reported, apart from lowish mpg for town driving and a continuously sooty exhaust that I have to clean every week.
Well a week on and there is more fuel left in the tank, doing the same daily trips (I used to just survive a week on half a tank) and the exhaust tips are very clean still amazingly.
Will keep monitoring, but impressed so far. The engine must have been running rich and the MAP sensor was stating high pressure in the system when it was not on boost.
Have you got a part number for it?
Sent from my SM-G930F using Tapatalk
Offline willk86
« Reply #11146 on: May 21, 2018, 07:59:49 pm »
Offline Joshy
« Reply #11147 on: May 21, 2018, 08:11:35 pm »
Finally transferred my new reg onto the car! :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11148 on: May 22, 2018, 04:43:53 am »
This is it;  038-906-051-D...do not get the 038-906-051-C because it is a 3 bar sensor and will not work unless tuned to use it.
https://www.darksidedevelopments.co.uk/products/vw-2-5-bar-map-small-probe-manifold-pressure-sensor-038-906-051-b.html
Offline willk86
« Reply #11149 on: May 22, 2018, 09:05:51 am »
Thanks pal, I have the same symptoms as you've described, hopefully this will sort.
Sorry everyone  for the double post as well
Offline Newbieintown
« Reply #11150 on: May 22, 2018, 06:02:51 pm »
Didn’t you change this yourself? Was a bitch of a job? Thanks
200bhp
Tornado Red
2006
« Reply #11151 on: May 22, 2018, 06:05:54 pm »
Had my main thermostat changed today the garage said it was a right PITA. Seems to get up to temp a lot quicker. Hopefully the 2.5 hours of labour charge will be worth it.  :happy2:
200bhp
Tornado Red
2006
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11152 on: May 23, 2018, 03:46:12 am »
You were actually asking "mjmallia"....but I answered your question as to which is the MAP sensor part number.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11153 on: May 23, 2018, 08:22:10 am »
New front brakes.  :jumping:
Offline willk86
« Reply #11154 on: May 23, 2018, 10:37:40 am »
Sorry pal, didn't check the user name, just assumed . Thanks though.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11155 on: May 24, 2018, 07:17:21 am »
Those are beauties...but not familiar with them or seen them before. Are those this set? https://www.vagbremtechnic.com/front-brake-kit-4-piston-brembo-calipers-with-362x32mm-2-piece-discs-bk0003/
« Last Edit: May 24, 2018, 07:21:56 am by ROH ECHT »
Offline Christiank
  • -Receive: 39
« Reply #11156 on: May 24, 2018, 07:22:44 am »
It is mate :) And it looks spot on!
 :party:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11157 on: May 24, 2018, 11:59:47 am »
I preferred to source the calipers and the pads myself because I could get them for a much cheaper price. I just bought the kit that comes with the discs, the custom caliper brackets and the braided oil lines. :smiley:
The discs are really light compared with my old ones (13 kg vs 8,6 kg). :grin:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11158 on: May 25, 2018, 04:06:19 am »
They are gorgeous...I never did a weight comparison with mine...I wonder now. Mine are Porsche 993 calipers and I have come to want new GTI caliper stickers to cover the ECS Tuning on them. Going to a vinyl shop to ask what they can come up with for high heat vinyl.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11159 on: May 25, 2018, 01:33:54 pm »
Yours are good looking too and should be light. If you upgraded from the OEM brakes you never had heavy front brake discs like I had before. :doh: :happy2:
Since now I had to get the calipers painted red, I opted for the GTI letters, like the new mk7 GTI Pack Performance have. Just make sure to check the adequate size of the letters for your calipers and that the vinyl letters are protected with a coat of heat  resistant clear varnish.  :smiley:
