Author Topic: What did you and your MKV do today?  (Read 2797619 times)
4ndy
« Reply #11265 on: July 03, 2018, 10:06:16 am »
Passed mot  :smiley:
Me too  :jumpmove:  Wishbone bush needs attention but all's good At least I didn't leave my air freshener hanging off the mirror this time.
Less paperwork too so I've save part of a tree also :thinking:
Offline Newbieintown
« Reply #11266 on: July 03, 2018, 09:24:33 pm »
Passed mot  :smiley:
Mine to no issues or advisors. 😊👌
200bhp
Tornado Red
2006
4ndy
« Reply #11267 on: July 04, 2018, 07:56:57 pm »
Ordered new wishbones. Forgot the bolts :thinking: :signLOL: in all my excitment
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11268 on: July 05, 2018, 10:50:01 pm »
Fitted Tyrol sports deadset kit, can still hear knocking, briiliant
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11269 on: July 06, 2018, 04:35:46 pm »
Steering column most likely now, right? :\
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #11270 on: July 06, 2018, 05:20:30 pm »
it might not be the steering rack see here http://www.mk5golfgti.co.uk/forum/index.php/topic,117043.15.html
I have a similar problem, but have been told my rack is ok thank god.
Black Ed30
« Reply #11271 on: July 06, 2018, 05:56:52 pm »
Nothing done today, but was asked today by a complete stranger if I wanted to sell him my car.   No chance  :grin:
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #11272 on: July 07, 2018, 01:44:10 pm »
Both rear wheel bearings replaced, peace and quiet now
« Reply #11273 on: July 07, 2018, 03:02:09 pm »
Good job.  I would have sprayed some zinc spray on those bare hubs personally as they do like to rust!
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #11274 on: July 07, 2018, 03:16:16 pm »
I did
Even put some anti seize on the hub bolt cap/cover edge as that seized too when trying to remove the old one
« Reply #11275 on: July 07, 2018, 03:47:12 pm »
I did
Good man  :happy2:  First time I took my rear wheels off after buying the car, I had to hammer/kick the damn things off because of corrosion!!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11276 on: July 10, 2018, 02:35:37 pm »
Just fitted the RS3 air ducts to my S3/Passat front control arms. I used the following part numbers:
-vent: 8P0 863 149 A and 150 A
-bolt: N104 222 03 (x2)
-nut: N 907 611 02 (x2)
-aluminium tube from the RS3: 8P0 864 133 (x2)
After torquing the bolts and nuts there's still a bit of wiggle in the vent. Anyone else has done this and know that it's expected to be this way? 🤔
I preferred to remove the OEM dust shields.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11277 on: July 10, 2018, 03:47:29 pm »
Do you know how much of a difference these make?
« Reply #11278 on: July 10, 2018, 04:48:42 pm »
Rear brake job as the pads were down to 4mm.  I don't like wearing them right down at the back as the calipers are pretty crap for lifespan when that happens.
I didn't realise VW did 'eco' pads.  Half the price, but half the bite I expect, so stuck with GTI ones, which are made by Ferodo.
I also bought a pair of shields to replace my rattling ones, but didn't realise I had to remove the bearing/hub assembly to fit them  :doh:  Annoying as I'd already done the hardest part - removing the caliper carrier bolts - before coming to that realisation!   So instead I opted for a repair washer for now.  I'll save the shields for when I do the rear discs and have a pair of bearing bolts to hand.
Fitted stiffer Eibach coilover springs.  425lb/inch at the back and 450lb/inch at the front.  Surprisingly no loss of ride quality, but flatter cornering  :smiley:
Offline wlallen
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,116514.0.html
« Reply #11279 on: July 11, 2018, 02:39:37 am »
Installed rear euro outer tails and wired them up as they would be if the car wasn't sold in NA.  Added a euro badge to the front grill.  Rear fog on order.
Sent from my SM-G930T using Tapatalk
Lon Allen
2008 VW Rabbit S (2.5L) 154K miles.
