Author Topic: What did you and your MKV do today?  (Read 2967856 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11475 on: June 01, 2019, 09:56:17 pm »
Without it my full beam is still halogen Even though I have retrofitted xenons.
Offline Ripstop
« Reply #11476 on: June 02, 2019, 01:18:17 pm »
Replaced the rear passenger side window winder mechanism. The old one had the wires rusting up so eventually it just becomes impossible to move. Those motors are damn powerful though as I couldn't move it by hand. Lubed some silicone grease on the new one and now smooth as a babies bum.
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
Offline Stupots
  • -Given: 18
« Reply #11477 on: June 03, 2019, 10:18:28 am »
At long last (after 4 years) I finally got a replacement tailgate sprayed and got around to fitting it on Saturday, this was due to the common issue of rust around the badge. I took it to AB Crush in Kent and they fobbed me off, but refered me to VW, but they never got back to me. The wings had already been done and due to the number of people being refused tailgate repairs under warranty, I never bothered chasing VW.
Anyway, here is the rust and the tailgates during swap. Not too bad a job, I'd certainly do it quicker the next time :)
I have a GT front bumper + genuine ED30 splitter and all the front panels etc to go on, but that is for another time.
Offline The Red Warrior
« Reply #11478 on: June 03, 2019, 11:33:19 am »
@Stupots good job
Does the colour match properly?
Offline Stupots
  • -Given: 18
« Reply #11479 on: June 03, 2019, 12:05:50 pm »
@The Red Warrior It's pretty good baring in mind I just sent the parts to be sprayed, I'm happy enough. It's LC9Z which comes in a few variations I believe?
I'd say if anything the particle size of the flecks is very slightly smaller, but with the tailgate there is not much that meets at the same angle, so hard to see. I think when I get the front bumper on I'll know for sure, as the bumper to wing join will show any issues. When it's on I'll give the car a good clean and a machine polish and post some pics. I'm hoping to do that in the next few months, as I'm having the front off to have the engine out (to change the clutch, turbo and intercooler) so will do the bumper then.
Offline coolhandluke
  • -Given: 28
« Reply #11480 on: June 03, 2019, 05:31:21 pm »
Exactly same place as mine.
Does it look repairable from the inside?
Offline Stupots
  • -Given: 18
« Reply #11481 on: June 04, 2019, 08:20:29 am »
Was that aimed at me @coolhandluke ?
If so, after taking it apart and taking the badge out, the corrosion on the inside wasn't bad at all. It starts at the metal edge fold/lip about 5mm back from the front panel and comes outside, so probably repairable if I was to do it again. The inside plastic panel comes off with 2 crews (inside the close grab handles) and then a hard pull, you'll need to take the wiper motor off to take the badge off as it hides one of the bolts. Once the badge it out you can assess the corrosion. The wiper arm can be difficult to get off.
  • -Given: 28
« Reply #11482 on: June 04, 2019, 10:46:32 am »
Many thanks for the info 👍
Offline colesey
  • -Receive: 89
« Reply #11483 on: June 05, 2019, 11:54:15 am »
Ordered TTRS top mounts / Meyle HD drop links / Creation deadset for a suspension de-squeeking project.
Offline GTi-Nugget
« Reply #11484 on: June 05, 2019, 08:30:40 pm »
Replaced my diverter valve with a revision G as the one in the car was a unknown, turns out it was a Rev D that looks like it's been in there for a looooong time.. cars running a lot better now
Also today I restored my headlights as they looked garbage, crystal clear now
« Last Edit: June 06, 2019, 06:53:21 pm by GTi-Nugget »
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11485 on: June 07, 2019, 11:11:09 pm »
Oil and filter, fuel.filter and iridium ngk spark plugs. Does seem a bit more urgent now.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #11486 on: June 08, 2019, 05:25:56 pm »
Gave her an overdue bath
Offline jaffa
  • -Receive: 44
« Reply #11487 on: June 08, 2019, 07:16:53 pm »
To get the blood off?
Offline Wadgti
« Reply #11488 on: June 09, 2019, 02:49:02 am »
Wot did u do to restore them? Thanks
Offline GTi-Nugget
« Reply #11489 on: June 09, 2019, 08:02:32 am »
Wet Sanded the headlights with 800, 1500 and then 2500 grit wet&dry sandpaper.
Then used Meguires PlastX polish, at first I rubbed it in with a cloth, then used a big cotton buffing wheel on a drill and finished with another polish using my Dremel on the lowest setting with a polishing pad.
Dremel part took absolute ages since the polishing head was so small but the finish came out so much better than I expected from using it.
Unfortunately I've now busted up my hand and have broken a finger so not sure when I'll get my exhaust, new boot handle or anything else done
Sent from my ANE-LX1 using Tapatalk
