Author Topic: What did you and your MKV do today?  (Read 2802115 times)
« Reply #11640 on: September 27, 2019, 05:13:54 pm »
Surely this would occur for any intake though?
It does.  It's not just the pipe diameter that affects throttle response/torque, it's also the length of the intake path.  The OEM intake is very short.  At least 30% shorter than most of the bath sponge on a drain pipe kits out there.
Most people only care about peak gains on the dyno and whooshing / sucking noises, so don't care about a loss of bottom end response.
I thought if I bought a forge intake it would have had that taken into consideration anyone wanna buy a twintake
God no!  No intake manufacturer goes to even 10% of the R&D that VW do  :wink:  What they are selling you is hp gains at the top end, and in that respect most intakes do deliver.  How long has it been fitted?  Give it a few weeks for the ECU to relearn and it might perk up a bit.  A lot of people do end up going back to the standard intake though  :grin:
Offline J66hhr
« Reply #11641 on: September 28, 2019, 11:34:51 am »
Revo mounts, track series powerflex anti lift kit along with a wheel alignment.
Offline neilw
« Reply #11642 on: October 01, 2019, 07:24:56 pm »
My car passed its MOT.
It needs new rear drop links. they look easy to change, so I've ordered them, and a new set of ARB bushes to put in as a preventative measure.
Needs new rear tyres as well, so I ordered a full set of Pilot Sport 4, it'll be good to compare them to the Eagle F1 4's that I've been use too. I thought it would be a good idea to change them before it gets R-Tech'd in less than two weeks!
Edition30 #0002 R-Tech Stage2
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11643 on: October 02, 2019, 08:09:53 pm »
Fitted drivers bucket seat with resistor wired into airbag loom to keep the other airbags working
Offline Matimcfet
« Reply #11644 on: October 02, 2019, 08:20:20 pm »
Drove it for the first time in 2 weeks! Anybody else making the trip to GTi festival this sunday?
Offline muff1991
  • -Receive: 69
« Reply #11645 on: October 04, 2019, 09:29:13 am »
eyed this up earlier in the year.. and forgot all about it!! got plans now ffs  :sad1:
Offline Matimcfet
« Reply #11646 on: October 04, 2019, 07:44:33 pm »
Anyone got any idea what the spark plugs are gapped too when you have a stage 1 (apr) map?
« Reply #11647 on: October 04, 2019, 07:51:11 pm »
They don't need gapping, just bung em' in.
Offline ljc19630
« Reply #11648 on: October 04, 2019, 07:56:22 pm »
Well, post R-Tech KO4 conversion, and despite the fact they did an AMAZING job, I needed to have the new Milly R32 zorst adjusted as tail pipes were sticking out too far. Took to my pals garage and re adjusted the back box, cut off tail pipes, re centred and re welded. Looks a million times better. I’d post pics but currently re painting the plastic lower skirt in gloss black, hence all masked up. Will pop some pics up tomorrow
Offline Matimcfet
« Reply #11649 on: October 04, 2019, 08:08:29 pm »
Well I tried this but the power is cut at like 5.5k... almost like its hitting limiter early :(
Offline ljc19630
« Reply #11650 on: October 04, 2019, 08:13:19 pm »
That’s not plug related. Get ya map checked bro
Offline ljc19630
« Reply #11651 on: October 04, 2019, 08:14:24 pm »
Should have said mine revs to 7200 without any problems
Offline Matimcfet
« Reply #11652 on: October 04, 2019, 08:15:25 pm »
Thing is before I changed plugs it was fine? Literally done like 8k since mapping and all was fine
Offline J66hhr
« Reply #11653 on: October 04, 2019, 08:26:40 pm »
Not the plugs.. had a similar problem power cutting when accelerating hard.. turned out to be the coil packs.. got 4 bosch coil packs from euros as i had no idea what make the old ones were..
Running stage 2 custom map with standered ngk r plugs..
 or plug a scanner on it
Offline kodirl
« Reply #11654 on: October 05, 2019, 08:45:38 am »
Picked up a standard manual 3dr GTI back in August.
Had the below works completed this week-
New calipers, discs and pads fitted.
New thermostat as the car was only heating to 70degrees.
New wishbone rubbers.
New rear shocks and bumpstops as the shocks were both leaking.
New timing belt and water pump kit fitted.
New rocker cover and gasket as old one was cracked and sealant used on it.
New cam follower.
Wheels refurbished and powder coated in Mercedes AMG light anthracite.
New outer CV boots.
Next on the list is full respray and fit new plastics all round too.
Sent from my Mi A2 using Tapatalk
