Author Topic: What did you and your MKV do today?  (Read 2801742 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11790 on: February 21, 2020, 11:03:11 pm »
You should drive around with it looking like that!  Maybe it's just me but I think that looks well cool  :grin:  Such a convenient way to attack door jobs, well done VW  :notworthy:
 :grin:
Offline Ripstop
« Reply #11791 on: March 04, 2020, 03:55:35 pm »
@Pudding
Quote
Have you got the most recent Helix with the billet pressure plate?  I've got the older one with the (steel) Sachs Sporting pressure plate and I hate it!!  Really hard to get a smooth bite pulling away at low revs.  And it's stupid heavy.  I'm thinking of going back to the standard clutch and living with the power limitations I hate it that much, but if you can convince me the Billet one is good, I might go down that route.   I've put about 60K on the older Helix and it's certainly held the power just fine, but awful to live with on a daily basis.
To be honest I dont know but I suspect I have the new billet version as the clutch appears to be pretty smooth and not overly heavy. After a car park session on the M25 though for 30 minutes when I first got it I did begin to notice my leg aching :( It is heavier but not burdensome in general driving.
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
Offline ljc19630
« Reply #11792 on: March 05, 2020, 10:29:04 pm »
I replaced the interior hatch back trim and lower interior boot trim with brand new OEM parts. Anal, I agree but they were the only parts that had marks, hence now looking brand new
Offline RobC
  • -Receive: 20
« Reply #11793 on: March 06, 2020, 06:49:30 am »
Did you get these direct from VW?
Offline ljc19630
« Reply #11794 on: March 06, 2020, 06:59:23 am »
Hi Rob
Via TPS bud as have a friend who owns an auto spares business. Wanted new parts, hence bit the bullet on cost as tailgate part was £155 and the boot part £41
Offline RobC
  • -Receive: 20
« Reply #11795 on: March 06, 2020, 07:31:03 am »
Hi Rob
Ah OK. Yeah, I have a friend who works at the dealers, assumed the parts werent going to be cheap! Can make all the difference though.
Offline ljc19630
« Reply #11796 on: March 06, 2020, 07:38:20 am »
Go for it. Was the only bits that were not to my “standard” and been bugging me for ages. Next thing is to get PDR done on a few small dinks on drivers door, and rear wing, which again, albeit small is bugging me and needs to be sorted
« Reply #11797 on: March 06, 2020, 03:23:48 pm »
@Pudding
Quote
Thanks mate!  Sounds just like my older style one then  :grin:  Unfortunately it will only get heavier! Mine's gone past half worn and my left leg is now ripped to match my ripped right arm  :grin:
On a more positive note, it's been reliable for the past 50 or so K, no juddering and no popped slave or master cylinders  :happy2:  The new DMF I put in with the Helix (LUK) doesn't like the clutch though.  Only lasted 2 years before it started rattling like a bar steward.  Sounds like a broken road drill when I pull away  :ashamed:
« Reply #11798 on: March 06, 2020, 03:28:14 pm »
Engine and (manual) gearbox oils changed.  Did the gearbox oil 5 years ago, which isn't that long considering VW reckon it's sealed for life, but the shift quality improved very noticeably.
The VW gear oil is now £25 a litre  :surprised:   Not many dealers seem to stock it anymore.  Had to try 4 local dealers to get it and in the end Audi had some.  None at any of the VW dealers.  Maybe they're phasing it out because of DSG?  The 3 bottles Audi had were covered in dust, so they clearly don't sell it very often.  Probably glad to shift it!
« Reply #11799 on: March 14, 2020, 11:01:40 am »
General servicing stuff.  Front wiper blades, which you can only get from the dealer for some reason?  £40!!  Halfords do the back one, but not the fronts.  Weird.
Annoyingly, I fitted this aerial and gasket 3 years ago with genuine parts and they're fooked already!  £28 for the aerial and a fiver for the gasket.  Things are getting more expensive but quality is going down it seems.  My missus's 18 year old MK4 is on it's original aerial and still looks fine.
Offline titchy
« Reply #11800 on: March 14, 2020, 01:01:29 pm »
Wipers.co.uk I get my blades from here good brands good prices
Offline Lucky ducky
  • -Given: 30
« Reply #11801 on: March 14, 2020, 05:06:29 pm »
Bosch 20 quid a pair
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11802 on: March 15, 2020, 02:49:00 am »
Today the MK5 sat in the garage all day...but I put together a list of stuff that I will be placing an order for real soon. I have quite a bit to replace for peace of mind that the MK5 will go another 20+ years.
This is the current list I have:
K04 turbo
"S3/MK6 Golf R" injectors
Downpipe(so to go back to a catted pipe)
Oil filter housing
Oil filter to block seal
Oil cooler to filter housing seal
Timing chain and VVT tensioner
Positive battery cable
Driver seat cover and foam
Left headlight assembly
Both rear arch liners
Front right lower arch liner
Belly pan/Baffle
Upgraded LPFP-DW65v
Thermostat
...and a few more.
« Last Edit: March 18, 2020, 07:09:16 am by ROH ECHT »
Offline Second
« Reply #11803 on: March 16, 2020, 12:31:05 pm »
Dropped my car off to have an LSD fitted  :driver:
Offline GTI DAZ
  • My Ride: Previous: Mk7.5 Fiesta ST, Current: None, future: MK5 GTI
« Reply #11804 on: March 16, 2020, 05:10:36 pm »
Tried to do brakes, rear caliper seized so wouldn't wind back, gave up and ordered new calipers. we go again at the weekend  :confused:
