Author Topic: What did you and your MKV do today?  (Read 2797959 times)
Offline Ripstop
« Reply #11910 on: August 21, 2020, 11:06:12 pm »
@TwebbGBC
Finally found it... maybe a bit pricey but for all that sagging and mouse nest I was happy.
NEW OEM VOLKSWAGEN VW GOLF V JETTA V BONNET HOOD INSULATION DAMPING 1K0863831D
https://www.ebay.co.uk/itm/201811643700
Rip
Stage 1 2007 Black Eddy  #1000 - VCDS Hex+Can (Novice coder). H&R springs, newish Bilstein B4's. Gen 3 Steering rack, Helix organic.  The car is *always* work in progress fixing and upgrading things.
Offline Jb55
« Reply #11911 on: August 22, 2020, 01:08:22 am »
@Ripstop
@TwebbGBC
cheaper here 233539757027 ebay item number
« Last Edit: August 22, 2020, 01:10:06 am by Jb55 »
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #11912 on: August 22, 2020, 04:27:12 pm »
I guess the second one is aftermarket. I think I'd spend the extra for OEM, but that's just me!
willni
« Reply #11913 on: August 22, 2020, 05:51:29 pm »
Had the old tints taken off my car and retinted by Pentagon Glass Tech.
Offline Rossimac
  • -Given: 78
« Reply #11914 on: August 22, 2020, 07:43:51 pm »
Looks great Will! Are the rear windows factory tinted? How'd the rear window turn out if not?
willni
« Reply #11915 on: August 22, 2020, 07:59:19 pm »
The rears were the standard green tinted glass, they got midnight tint put over them to match the mk7 golf optional rear tint level which is about 90%. Flawless job carried out, really pleased with them :smiley:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11916 on: August 27, 2020, 10:11:13 pm »
Was bored so I did a timing chain stretch test with VCDS just for that peace-of-mind feeling.
Spec is ±5°KW, you hope to see no more than ±3°KW, and mine was -2°KW. So, looking tight still with 155k miles on the old MK5 FSI BPY engine w/K04 that's never had the N205, chain, or tensioner replaced.
« Last Edit: July 31, 2021, 01:57:25 am by ROH ECHT »
« Reply #11917 on: August 28, 2020, 01:37:18 pm »
Spec is ±5°KW, you hope to see ±3°KW, and mine was -2°KW. So, looking tight still with 155k miles on the old MK5 FSI BPY engine w/K04 that's never had the N205, chain, or tensioner replaced.
That's good going and highly unusual!  Normally expect to see -3 or -2 at idle when cold/warming up, but after a drive that can move to -1 or 0 as the VVT moves things around.  Once the chain wears to the point of the tensioner running out of travel, that's when things can drift to -5KW or more.  But that's only 5 degrees, which isn't even a tooth off.....so I don't think things will ever get so bad it runs like crap......unless the chain snaps!
Offline Mark_DF05
« Reply #11918 on: August 29, 2020, 09:43:14 pm »
I know what you mean but as I couldn't see it, it was easy to ignore  :grin:
my leaking windscreen wash bottle on the other hand...
Funny you mention that.  After some front bumper work on mine I noticed dripping down by the driver's side wheel after refitting it.  Long story short after removing the bumper several times to check the pipework......turned out I hadn't quite clipped the main pump > xenon washer hose in properly  :doh:  Literally had to spin that clippy thing around a few degrees and it solved it.
Winner. Hoping mines something simple like that, it’s a job for this weekend
Offline DrG_GTi
« Reply #11919 on: September 03, 2020, 09:00:13 pm »
2007 56 plate, 69k miles - had cam belt,  waterpump, 2x F1 asy 5 tyres, major service, mot (pass), expensive trip to the indy garage but all needed
Also fitted brembo pads to front, and painted the rusty hubs satin black while I was at it. Still love the car after 6 years of ownership.
Cleans up well too!
Sent from my SM-G988B using Tapatalk
Offline JTI
  • -Given: 19
« Reply #11920 on: September 07, 2020, 10:50:14 pm »
Spent the weekend refurbing and painting my wheels. Really pleased with the results, still need to repaint the calipers which has got me thinking about maybe trying a different colour. Perhaps black? Have also ordered some new centre caps as the wheels just look weird without them. Finally a spot of Meguiars tyre gel to finish them off :)
Also used Meguiars Ultimate Black on the side skirts and rear bumper which I was really impressed with. Looks kinda patchy in the pic but that was before it had dried properly, they look almost new now!
Offline colesey
  • -Receive: 89
« Reply #11921 on: September 09, 2020, 12:10:14 pm »
A fresh pair of ps4 on the front to replace the slow-leaky old ones. The rejuvenation effect from fresh tyres really is impressive.
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #11922 on: September 09, 2020, 01:32:57 pm »
I bought a cheap ebay one last month.  It's much thinner than the OEM one, and the reflective silver bit looks like it was cut and stuck on by someone who can't see!
willni
« Reply #11923 on: September 28, 2020, 07:50:20 am »
Last wash and a bit of wax before I put it away for the winter.
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« Reply #11924 on: September 28, 2020, 10:22:43 am »
[Looks stunning]
