Author Topic: What did you and your MKV do today?  (Read 2796628 times)
Offline TheBALDpuma
« Reply #11925 on: September 29, 2020, 02:19:10 pm »
My wheels are being refurbe as we speak, looking forward to the result! If I can remember how to post a photo I will do! :grin:
Offline GPem3:16
« Reply #11926 on: September 30, 2020, 09:01:21 pm »
Mfsw buttons dsg.
Easy as.
Sent from my SM-A715F using Tapatalk
Offline GPem3:16
« Reply #11927 on: September 30, 2020, 09:01:27 pm »
Mfsw buttons dsg.
Easy as.
Offline Stupots
  • -Given: 18
« Reply #11928 on: October 01, 2020, 06:12:22 pm »
Today (and yesterday) I mostly fitted the Mk7 style climatronic controls and Air Quality Sensor (and single motor recirculation flaps). Also passive TPMS and a USB charging port.
Spot the difference... same car 5 years apart. Love how you can update these things!
Before
After
If you have dual motor recirculation flaps, updating to the later single motor flaps (to stop the windows misting after the Mk6/Mk7 panel upgrade) is quite a job, I wouldn't want to do it again.
« Last Edit: October 01, 2020, 06:44:38 pm by Stupots »
willni
« Reply #11929 on: October 01, 2020, 09:06:24 pm »
Before
After
Where did you get the mk5 to mk7 trim surround? or did you make it yourself?
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« Reply #11930 on: October 01, 2020, 09:31:11 pm »
The manual bonnet latch had been playing up for a while but had become completely useless recently.
Time for a good clean!
Took it off, very simple, just 3 torx bolts. Dipped it in petrol to move the grime.
Thought perhaps a soak would be better.
Which went horribly wrong!
New container.
After some scrubbing, dismanteling and some more scrubbing, the end result is working but not perfect. Add some oil to the joints and your good to go!
 Was pitch black when i put it back on but it does work now.
Offline Stupots
  • -Given: 18
« Reply #11931 on: October 01, 2020, 10:13:31 pm »
@willni I made it. Turned out better than I'd hoped.
Standard Mk5 one for colour comparison, the custom one has been sprayed.
I want to make another one with the silver trim just under the long row of buttons as on the Mk7, so a bit more cutting/shutting on the next one. Interestingly, while the Mk7 and Scirocco/Passat panels look the same the holes for the dials and off/sync buttons are bigger on the Mk7 panels.
Offline GPem3:16
« Reply #11932 on: October 01, 2020, 10:57:33 pm »
What did you make it from can I ask?
What was the starting panel?
Offline Stupots
  • -Given: 18
« Reply #11933 on: October 02, 2020, 06:44:45 am »
@GPem3:16 I did the same as @ady-uk and others; Scirocco bottom panel and Golf top. I'm not sure where everyone else joins them, but I joined them where the bit that sits behind the vent panel and over the top of the stereo meets the main panel. If you can get the length of the bit either side of the stereo to the correct length and nice and square you're onto a winner, I also adjusted some of the rear clips and removed the top 2 as they are slightly different heights to a Mk5 panel.
This is the paint that I found matched well and was very forgiving. I've taken some pics so maybe I'll do a guide at some point.
https://www.ebay.co.uk/itm/114424544966
Offline GPem3:16
« Reply #11934 on: October 05, 2020, 01:45:34 pm »
Fitted and Coded CECM highline to my Eddy #0627
Well happy to now have more features available.
All I need now is some close to Newport for some Highline clocks coding in
Offline Stupots
  • -Given: 18
« Reply #11935 on: October 10, 2020, 11:33:58 am »
Took a night time shot of the new AC controls with the rest of the upgrades. Really pleased with the look in day or night now; it all finally matches.
Offline ahsan82
« Reply #11936 on: October 10, 2020, 11:55:35 pm »
changed my rcd300 to the rcd510......big upgrade from the rcd300
shout out to pashka for supplying me with a new canbus gateway
sadly for some reason imageshack wont allow me to upload any pics.... but looks so much nicer in the cabin now!!!
Offline probedb
« Reply #11937 on: October 11, 2020, 09:34:56 am »
For the past few days I've been trying to diagnose a noise that seems to start on a long right hand turn. Decided it must be suspension/steering related. This car's cost me more than a 1994 RX7 was costing me  :laugh:
Offline Danthefourwheeler
« Reply #11938 on: October 19, 2020, 07:07:36 pm »
Woah that's epic dude, where did you grab these from?
Sent from my Pixel 5 using Tapatalk
Offline GPem3:16
« Reply #11939 on: October 20, 2020, 03:55:28 pm »
Any help here please. Blutooth kit for module and rns510
Canbus I'm guessing is the twisted wires.
Any help with the others.
