Author Topic: What did you and your MKV do today?  (Read 2796601 times)
Offline GPem3:16
« Reply #12060 on: April 09, 2021, 01:44:15 am »
2x new wings
2x new front struts sachs and top mounts
Set new 35mm lowering springs
Exciting times
Sent from my SM-A715F using Tapatalk
Fitted drivers side wing. Looks so clean now.
Doing the other side tomorrow. Will take some pictures if anyone is interested. Pretty simple really, hardest part was sitting it true.
Yeah can you take some photos on step by step how you did it please. I've got some rust bubbles starting to appear and would like to see how it's done to replace it.
Will do
Offline brian_badonde
« Reply #12061 on: April 09, 2021, 10:27:45 am »
Where did you get the wings from? Look like a really good match.
Sent from my SM-G960U using Tapatalk
Offline GPem3:16
« Reply #12062 on: April 09, 2021, 10:34:11 am »
They're spot on, my brother is a sprayer and he was impressed by them.
Lothian autoparts UK eBay.
« Reply #12063 on: April 09, 2021, 10:46:01 am »
Cheers, will check them out.
Offline jacksosi
« Reply #12064 on: April 09, 2021, 11:51:09 am »
...something I occasionally wonder about...what are those detailed sections below the headlights and above the fog light area for?
Just for detail, or do some models have something else in that section?
Black MkV Gti (Nov 2008), no modifications
Offline GPem3:16
« Reply #12065 on: April 09, 2021, 11:52:01 am »
Xenon headlight washer jets
Offline jacksosi
« Reply #12066 on: April 09, 2021, 12:46:30 pm »
That solves that, thanks
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12067 on: April 09, 2021, 01:03:45 pm »
Fitted one aerocatch and killed my dremel.
Will fit the other when my new dremel arrives.
Offline pandaman
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,115571.0.html
« Reply #12068 on: April 10, 2021, 12:39:36 am »
How well did the panels fit? Have been thinking about lothian wings for a while now, colour matching and fitment is whats stopping me.
Offline Stupots
  • -Given: 18
« Reply #12069 on: April 15, 2021, 11:50:00 am »
Had my extra Ed30 alloy refurbed for a spare to match my others previously done by www.lepsons.com in Gillingham, Kent (in Light Anthracite)
Now to get tyres fitted to the other 4 and put them on the car :)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12070 on: April 15, 2021, 05:13:04 pm »
Passed the MOT after being off the road for a year.
Offline colesey
  • -Receive: 89
« Reply #12071 on: April 15, 2021, 07:18:11 pm »
Had a slow leak on rear wheel rim fixed and gave it a wash.
Offline fakie1977
« Reply #12072 on: April 15, 2021, 08:05:57 pm »
Preparing my 18” Monza’s to replace my 17” winter set (since weather is getting warmer). Had a bit of kerb damage to 2 of the wheels and whilst they were still off I wet sanded and polished it back. Finished with a few layers of lacquer and then polished it back. Because of the diamond polish facing its not 100% but its only now really noticeable up close. Run out of time but will clean them all and put some gtechniq C5 before swapping them over this weekend. Overdue but the 17” will be refurbed before being stored away again.
Offline davidpalen
  • GTI mk5 2006
« Reply #12073 on: April 19, 2021, 10:53:49 am »
Today (and yesterday) I mostly fitted the Mk7 style climatronic controls and Air Quality Sensor (and single motor recirculation flaps). Also passive TPMS and a USB charging port.
Spot the difference... same car 5 years apart. Love how you can update these things!
Before
After
If you have dual motor recirculation flaps, updating to the later single motor flaps (to stop the windows misting after the Mk6/Mk7 panel upgrade) is quite a job, I wouldn't want to do it again.
Hello, I have seen all the modifications you have gone to your mk5, did you do it yourself or did you take it to a garage to do all those things? Is it a case of buying the parts slowly on eBay, totalled cars etc?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12074 on: April 19, 2021, 02:58:47 pm »
gave it a wet vac as a bit of mould had appeared on the seats after it's year long hibernation.
