Author Topic: What did you and your MKV do today?  (Read 2794821 times)
Offline Stupots
  • -Given: 18
« Reply #12075 on: April 19, 2021, 06:25:39 pm »
Hi @davidpalen I did all the work myself. It’s my 7th Golf and been fiddling with them since 1992  :happy2:
Offline davidpalen
  • GTI mk5 2006
« Reply #12076 on: April 19, 2021, 06:27:02 pm »
Is it easy to do? Are you happy if I ask you questions in the future? Please send me a PM if that's ok... Thanks
Offline Lewo
« Reply #12077 on: April 19, 2021, 11:03:44 pm »
Nice wheels Stupots, had mine done there too.
Curbed one couple of months ago so need to take that one back.... :doh:
Offline Sebas_theFish
« Reply #12078 on: April 20, 2021, 01:14:45 pm »
Today (and yesterday) I mostly fitted the Mk7 style climatronic controls and Air Quality Sensor (and single motor recirculation flaps). Also passive TPMS and a USB charging port.
Spot the difference... same car 5 years apart. Love how you can update these things!
Before
After
If you have dual motor recirculation flaps, updating to the later single motor flaps (to stop the windows misting after the Mk6/Mk7 panel upgrade) is quite a job, I wouldn't want to do it again.
That turned out really well! I've decided I'll give it a go myself, however using the silver coloured trims as these are what I already have installed in my car. I assume you used the Scirocco climatronic controls and not the Golf ones?
« Last Edit: April 20, 2021, 01:17:13 pm by Sebas_theFish »
Offline Stupots
  • -Given: 18
« Reply #12079 on: April 20, 2021, 04:28:08 pm »
@Sebas_theFish Yes, I used the silver Scirocco trim for the main part and a standard panel as the donor for the bit that wraps around the top of the head unit.
I used a Passat control panel, specifically part number 3AA 907 044 BQ.
Good luck!
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« Reply #12080 on: April 22, 2021, 11:04:28 am »
MOT'd for another 12mths, passed with no advisories as it has done for the past 7 years #preventative maintenance!!!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vqqbsl75592ji23jjhiu3c3d44&/topic,19740.0.html
« Reply #12081 on: April 22, 2021, 11:34:19 am »
That is satisfying.   :happy2:
Mine has has a string of advisories (tyres/brakes/emissions) over the last 2 years but hoping to get a clean sheet next time. That will be nice for a 14yo car.
Offline JTI
  • -Given: 19
« Reply #12082 on: April 22, 2021, 09:47:34 pm »
Spent a good chunk of the afternoon running outside to turn the alarm off on my MK5, as it kept going off randomly. Ended up taking the alarm fuse out and giving the connector going to the boot handle a good wiggle, as I think it's down to that failing. It's gone quiet now so hopefully it's fixed itself for now and it's not just a flat battery  :smiley:
Have ordered a replacement boot handle anyway as I never liked the flat old style one on mine. It's a MK6 one and am hoping to colour code the background on it as I've liked the ones I've seen on here.
Offline MKMike
« Reply #12083 on: April 23, 2021, 04:27:53 pm »
money light came on so thought I'd take it to VW dealer as ours does a video of the undercarriage and I wanted them to have a look.
Turbo boost pipe seal was the issue. Washer replaced.
171 squid  :smiley:
« Reply #12084 on: April 23, 2021, 09:31:14 pm »
Ditto.  7 years of ownership and 7 passes  :smiley:
My local dealer does the MOTs and brake fluid flushing etc, and I get the usual "Let me know if you want to sell it" from the master tech every year  :grin:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12085 on: April 24, 2021, 04:33:05 pm »
I began looking into why the hatch-pop kit I installed more than ten years ago to be sure I installed it correctly. As it has never really opened the hatch 100% of the time. It does open if the summer heat is present...and I am parked in the sun...and a window is cracked open, having first used the key fob to open them. I installed a new set of spring bump stops and the two hatch supports less than two years ago. I also went through the install instructions today, provided by ECS Tuning as well as a newly found DIY vid I by USP Motorsport (both linked below). I noticed a difference between them and why my curiosity was recently peaked. ECS Install Instructions states with the stops loosened; you shut the hatch_open it_and tighten the bump stops at their newly adjusted position. Which is how I did mine. In the USP vid he states with the bump stops loosened; you shut the hatch_open it_pop the bumps outward an additional two clicks_and then tighten the bump stops. I can say after popping the bumps out two clicks; the hatch still doesn't open fully in the temps of the garage. And in looking at the stops through the gap with the hatch closed, I can see the bumps are fully compressed in the 'hatch closed position'. So I've re-adjusted them to only being popped out one click so there is a tiny bit of room for the spring to compress. I've always accepted the Hatch-pop mod only pops the hatch open and isn't meant to fully open the hatch as advertised...while being aware it does sometimes fully open when warm.
ECS Instructions:  http://bd8ba3c866c8cbc330ab-7b26c6f3e01bf511d4da3315c66902d6.r6.cf1.rackcdn.com/PDF_10744_Volkswagen_MKV_Hatch_Pop_Kit_InstallationR2.pdf
USP DIY vid...bump adjustment begins at 3:00:
« Last Edit: April 28, 2021, 03:29:21 pm by ROH ECHT »
Offline Havelin150
« Reply #12086 on: April 24, 2021, 09:15:45 pm »
I treated the edition 30 to an anti lift kit, unfortunately my repayment was in the form of a snapped bolt. Brilliant.
Offline Stupots
  • -Given: 18
« Reply #12087 on: April 25, 2021, 08:16:10 am »
Nearly been there. They are steel (one use stretch bolts) in alloy and the bolt end thread protrudes though the top of the subframe. So it’s a great idea to clean that bit of the thread off with a wire brush and a bit off WD40 before even attempting them. If they pick up on the thread and start to go tighter don’t force them, back off 1/4 turn and then try 1/2 turn, repeat.
I took 45 mins to get 1 bolt out and another half hour for another. 1 wasn’t playing ball so I wound it back in and replaced just the bush in situ. All of this doesn’t help you but maybe will someone reviewing this thread in the future.
Knowing how tight that would have been to cause the bolt to snap, it’s not coming out easily. Maybe you could get a bolt welded to the protruding end above the subframe and wind it through the other way? Good luck and please let us know your solution.
Stu
Offline fakie1977
« Reply #12088 on: April 26, 2021, 09:52:13 pm »
Got my 17” winter set of monzas powder coated anthracite since I changed them over. Have to wait till next winter to see them on the car.
Offline Fallout-NL
« Reply #12089 on: April 29, 2021, 10:01:09 am »
Those wheels look great. Love the colour.
