Have an led light out in the 3rd center brake light ;[
Thanks to the design, that means I will have to replace the spoiler as well as the light, including paint.
I don't get why VW did not make that light removable separately from the spoiler???
Have a read of this thread, should help.
http://www.mk5golfgti.co.uk/forum/index.php/topic,50646.0.html
Plus this one
http://www.golfgtiforum.co.uk/index.php?topic=121067.0
Thank YOU! As mentioned in one of the threads, "What have I got to lose?"
It does appear there is an issue with the re-install being exactly solid as there is mention of adding double-sided adhesive tape. Hmmm?
'Reading for a rainy day':
My original 3rd light was replaced shortly after I bought my MKV in Nov. 2006. The car had 78 miles on it and the third brake light was out. They pulled off the spoiler and replaced the whole thing
. I couldn't believe my brand new car was already in need of having work done to it.
Also, the center dash diffuser vent was dented. It was replaced at the same time.
During that process the trim around the vent was scratched. So I went back and had that trim replaced.
Then the trim below it, around the stereo was chunked up badly.
So I had to go back for that one, but the trim
finish had changed so all of the center dash trim bits needed to be ordered and then replaced.
So when it went back for all of those to be installed, a tech opened the passenger door too carelessly and took out a chunk from the door strip.
So then that strip needed to be replaced and painted.
I think I had my new car for less than a week of that 1st month ;[ BTW, I've never returned to that dealership since then.
Any thoughts/feedback/reports from those with an upgraded front ARB along with the rear ARB would be appreciated greatly...thinking of finishing off my mods with that bit.
