Author Topic: What did you and your MKV do today?  (Read 2744727 times)
« Reply #3120 on: January 11, 2013, 09:02:16 am »
Real nice, yes. Which double-sided bonnet do you have, OSIR?
....Thanks  :drinking:
Yes, it's an OSIR and vented version. Using the unscientific 'palm-of-hand-test', my engine bay definitely feels cooler after a journey and the bonnet is also cooler to the touch.
^ The AeroCatches are false carbon and the real carbon is painted on the topside.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=rh2tq98fgmb29e186drc401e1c&/topic,19740.0.html
« Reply #3121 on: January 11, 2013, 10:00:54 am »
That's down to the thermal property of Carbon Fibre, I doubt the engine is running any cooler.
« Reply #3122 on: January 11, 2013, 10:26:07 am »
....Sure, the carbon's thermal properties will reduce the temperature to the touch when the bonnet is closed.
I agree, the engine itself won't be running any cooler but I think that due to the vent, hot air generated within the closed engine bay will rise and be extracted, hence the ambient engine bay temperature may be cooler - It certainly feels so (unscientifically) when opening the bonnet after a journey compared to when I had an OEM steel bonnet.
Sorry if I wasn't clear enough before.
Saintsteve
« Reply #3123 on: January 11, 2013, 10:57:21 am »
Dropped mine to the body shop today, pick up next Wednesday, then it's off to DMR Thursday for some more attention for another 7 days away  :sad1:.
« Reply #3124 on: January 11, 2013, 11:00:35 am »
....What? Already again?  :surprised:
Saintsteve
« Reply #3125 on: January 11, 2013, 11:09:33 am »
The pursuit for perfection Robin takes time  :wink:
« Reply #3126 on: January 11, 2013, 11:49:02 am »
You can't polish a turd Steve.  :wink:
Offline ArildStavrum
« Reply #3127 on: January 11, 2013, 12:12:42 pm »
but you can roll it in glitter  :happy2:
« Reply #3128 on: January 11, 2013, 12:19:15 pm »
Actually I believe you can shellac it and give it a shiny finish.  :smiley:
Saintsteve
« Reply #3129 on: January 11, 2013, 12:39:51 pm »
It's A1 wheels in Solihull is the reason for my recent return. DMR have been very kind to help with an issue that's gonna be sorted  :smiley:
  • -Receive: 291
« Reply #3130 on: January 11, 2013, 01:52:29 pm »
Is the bonnet scratch still there?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #3131 on: January 11, 2013, 06:27:46 pm »
TRS888 - This might help you out. I did mine a while back but mine are Gen 3 controller so maybe different to yours.
http://www.my-gti.com/2158
thanks
ill have to show that to my friend which will hopefully help him in figuring out a way for it to work.
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #3132 on: January 11, 2013, 06:33:27 pm »
TRS888 - lighting mods looking good. I was thinking about the bold sport door LEDs, but sounds like you've had quite a bit of hassle with them.
hi
thanks, im really loving them now. they were actually quite easy to do once i knew what to do. i think maybe because of the options my car came with, it doesnt have the highline version of the door controller if there is such a thing. not all 32 pins are present in the door controller.
i used pin no 1, and then piggy backed onto the pin no 2 (already had an earth in there)
if you just remove pin 2 and put the new light in there then the door window switch isnt illuminated. (may have caused other problems but i did the piggy back of the new light wire into the earth into pin 2) so everything works.
happy with the results, and me and my brother did the same thing to his car last night, didnt take as long, as we knew what to do. but looking good all the same.
if you're local i dont mind giving you a hand! :happy2:
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #3133 on: January 11, 2013, 06:50:18 pm »
I got a revision G DV fitted today in the hope it would cure my problems. It certainly seems to have done the trick!  :smiley:  The old original '05 DV was well split! The car is driving nicely again, it feels great!  Paid £60 for labour and £38 for the part itself at my local indy. Is that about average for price?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #3134 on: January 11, 2013, 06:52:26 pm »
think its ok.
i paid about £45 i think for DV but fitted myself (wilth my bros help) took about 40 mins
actually i prefered it when it was split for the noise :grin: i love the turbo sound but prefer the speed  :jumping:
« Last Edit: January 11, 2013, 06:55:43 pm by trs888 »
