Author Topic: What did you and your MKV do today?  (Read 2819602 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #330 on: September 05, 2011, 07:32:19 pm »
I'll try swapping 1 & 3 or 2 & 3 but theyre new Coilpacks mate  :sad1:
If that doesn't do it then I couldn't imagine what it would be. With a misfire showing up on data logs it would have to be due to something electrical.
Unless, there is a slight chance, there is some build up on the intake valves that is preventing combustion pressure due to a slightly open valve. But I don't know for sure if the data logs would show this in this case.
« Reply #331 on: September 05, 2011, 07:36:04 pm »
Haven't had a chance to do any proper logging it was just counting on basic measuring.
@ 59k good chance of the carbon on intake valves, I mentioned it to mechanic at Vw today and he looked at me blankly as if to dismiss it withou even giving it thought as if I hasn't a clue what I'm on about :(
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #332 on: September 06, 2011, 07:31:52 am »
I too am learning that most Mech's are the ones who don't have a clue about what goes on with our FSI's in the real world. Mine thought that the cam followers will not wear once you have changed the intake cam to the version 'B'. He thought, possibly because VW told him, that the version 'A' cam is what causes everything to go wrong with that. :stupid:
Today I put my MKV to sleep (KILL MODE) for two weeks while I'm away in Italy.
« Last Edit: September 06, 2011, 07:34:26 am by ROH ECHT »
Offline calculon
« Reply #333 on: September 06, 2011, 09:44:45 pm »
Changed the timing belt today. What a bitch is that one part belt cover ... Anyways, new timing belt, new filters, new oil, new spark plugs :-)
Didn't have the time to replace the cam follower. Anyone got a pointer to the correct procedure to remove it? I don't have a pressure valve since I have a very early revision of the axx engine. How do I get rid of the pressure? Pull the fuse and start the engine until it runs out of petrol?
Also noticed I have a B revision diverter valve. Ordered a D revision, just to be sure.
« Reply #334 on: September 06, 2011, 09:51:13 pm »
There's a spot on guide on doing cam follower on here, quick search will bring it up  :happy2:
How much is the revision D?  :happy2:
Saint Steve
« Reply #336 on: September 06, 2011, 10:11:50 pm »
It's near £50  from memory at vw in the uk
Offline 81lly
« Reply #337 on: September 06, 2011, 10:34:33 pm »
Went up to Arndale Shopping Centre in this terrible weather!
Offline mb
  • -Receive: 29
« Reply #338 on: September 07, 2011, 06:05:33 pm »
Wet sanded the stone chips on my bonnet and wings!  :scared:
« Reply #339 on: September 07, 2011, 06:06:29 pm »
Brave.  Pics?
Offline mb
  • -Receive: 29
« Reply #340 on: September 07, 2011, 06:11:02 pm »
Brave.  Pics?
Couple in the Detailing Section
« Reply #341 on: September 07, 2011, 06:12:15 pm »
Just came across it lol
My bonnet is hammered, excuse for 'needing' a carbon bonnet.  :innocent:
Offline calculon
« Reply #342 on: September 08, 2011, 06:50:04 pm »
www.mk5golfgti.co.uk/forum/index.php/topic,8339.0.html
Thanks for the link, that's a pointer in the good direction. Seems I got lucky again, a hpfp with 2 steel tubes and no pressure release valve. Seems the method to do it, is remove the electrical plugs, start the engine and leave it running for about 10 seconds. The pressure should lower to about 6 bar. VW then advises to 'quickly' get the thingie apart, since the pressure rises because of temperature. Something for next weekend perhaps. As for the price, no idea yet.
« Reply #343 on: September 08, 2011, 06:53:16 pm »
Picked up the Cupra after new front bumper and some gloss black paint  :smiley:
Had an alignment check;
Picked the car up this evening  :innocent:
They have done alignment.  Feels as though its wandering to the right a little though...
Had the oil seal fixed FOC  :smiley:
Offline Jungle_Faced_Jake
« Reply #344 on: September 08, 2011, 07:03:53 pm »
Got Revo'd  :grin:
