Author Topic: What did you and your MKV do today?  (Read 2831040 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #3510 on: February 07, 2013, 12:47:31 pm »
S3 alloy FMIC well worth the money and effort
01455 617233
Offline gigolo456
« Reply #3511 on: February 07, 2013, 12:55:49 pm »
toying with the S3 one, but hearing good things about the Twintercooler and THS intercooler, but is the extra outlay worth it!!??  :confused:
Offline R-tech-Nick
  • -Receive: 30
« Reply #3512 on: February 07, 2013, 01:52:02 pm »
I am not a fan of the forge twin inter cooler setup there is still going to be a pressure drop across the stock core and cannot see the reason for doing it, gimmicks??.  The S3 cores bring the pressure drop down by 3-4psi and imo one of the best oem mods for the gti for both cost and performance.  The THS is a good setup and works well but only going to improve over the s3 cooler if the setup is running 340+bhp.  Only splash out money if its needed, stock with the cheapest option for your target power which in the case of a k03 tfsi is the S3 290quid oem core which will happy flow as much as the k03 can give.
Nick
01455 617233
Offline gigolo456
« Reply #3513 on: February 07, 2013, 01:58:47 pm »
Cheers Nick. Did I hear you correctly last yr when you suggested that you would lose some torque with an S3 intercooler??
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3514 on: February 07, 2013, 03:31:06 pm »
Nick
The S3 fmic is sufficient for all K03's, most normal driving and regions, yes. I usually only recommend the S3 upgrade when asked even though I have both along with a K04 upgrade. For the price you cannot go wrong there. What Nick says often happens if both are installed, however, I have become a pro at adjusting the wastegate actuator for boost level adjustments. It only takes me about five minutes to do this now having gone through it a number of times dialing in my own boost from when it was 3 psi below specified. I just dropped the boost one psi a week ago.
« Last Edit: February 07, 2013, 03:34:38 pm by ROH ECHT »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3515 on: February 07, 2013, 03:34:34 pm »
^^^ I take it you adjust the N75 via VCDS/VAS, not physically?
'07 Red manual
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3516 on: February 07, 2013, 03:37:19 pm »
No, haven't been shown that yet. So yes, done physically. But now I may do some roaming around in vcds looking for this..
Offline gigolo456
« Reply #3517 on: February 07, 2013, 03:51:05 pm »
Nick @ R Tech physically adjusted mine with great results!!  :congrats:
  • -Receive: 427
« Reply #3518 on: February 07, 2013, 04:56:20 pm »
Valeo LED rear lights added (big thanks to markymark), also had side skirt repaired (again  :laugh:) and then spent all afternoon giving her a clean and polish, sealed and waxed the new wheels too...
Saintsteve
« Reply #3519 on: February 07, 2013, 04:57:49 pm »
My turn to say nice job  :signLOL: :congrats:  :happy2:
Looking sweet!!
Offline Kalpsn2000
  • -Receive: 56
« Reply #3520 on: February 07, 2013, 05:03:36 pm »
Very nice :happy2:
Love those rear lights (I might be a bit biased though :wink:)
Offline itismebigd
« Reply #3521 on: February 07, 2013, 06:36:48 pm »
Martin, your car is absalutely awesome buddy love everything about it,im going to have the same thing done ie colour code the bumpers and s/skirts your car is an inspiration for me anyway keep up the good work pal,totally minted gti fair play to you :congrats: :congrats:
Dougie :happy2:
Offline scottm72
« Reply #3522 on: February 07, 2013, 09:40:13 pm »
Looking sweet!!
impressive looking results there, everything just looks like it ---FITS WELL---
might have to bite the bullet and get them rear clusters
where did you decide to get them from eventually,
noticed you didnt change the inner red lense cap, wasnt sure myself if i would bother swapping it out either
looking way good martin  :happy2:
« Reply #3523 on: February 07, 2013, 09:47:22 pm »
Scott do you mean the fog light lens/aspect.  :smiley:
Offline scottm72
« Reply #3524 on: February 07, 2013, 09:55:32 pm »
yes the one side red and one side white look, noticed some people have removed the fog light red lens cover to give it the same white look on both sides then inserting a red bulb on the fog side instead of the red lens cover.
Not sure if they replace it with another clear lens on top of the red bulb or just leave the lens out completelly.
Only thing that has held me off so far from buying these rear clusters as im not sure about opening them up for the wire change etc incase i make a pigs ear of it unless i can buy a set pre done.
cheers  :drinking:
