Author Topic: What did you and your MKV do today?  (Read 2798547 times)
Offline Dave7692
« Reply #6030 on: March 15, 2014, 05:58:04 pm »
NEW WHEELS  :laugh:
Very happy with them, absolutely mint, got them with Perelli Sport tyres too.
Looks good but please lower it a smidge!  :happy2:
Yep, it does desperately need lowering, thats next on the list so will happen soon  :smiley:
Offline Banham
  • GTI MK6
« Reply #6031 on: March 15, 2014, 06:56:07 pm »
Went to Aks for a service and Alex managed to find out the problem i was having when my car was on the rollers at r-tech  :star: turned out i had the wrong fuel filter on the gti
Offline adminkatana
« Reply #6032 on: March 15, 2014, 09:18:09 pm »
Had new tyres and refurbed Monza Shadows fitted.  :smiley:
Offline Airz182
« Reply #6033 on: March 15, 2014, 09:39:39 pm »
Job done for today:
Cleanup coilovers
And wind them down a tad!
End up painting the rear trailing arms and other bits!!
Instagram- airz182
« Reply #6034 on: March 15, 2014, 09:41:46 pm »
Think your springs and adjusters are on upside down
Offline Airz182
« Reply #6035 on: March 15, 2014, 09:50:34 pm »
I thought the same as i thought watch a stupid idea! (Hard work to adjust them) but did a google search before and thats the way it Said to do it, the car came with them setup like this. Do you think its ok like this?
Instagram- airz182
« Reply #6036 on: March 15, 2014, 09:58:27 pm »
100% upside down I have had loads of coil overs and not one has been upside down
Offline Airz182
« Reply #6037 on: March 15, 2014, 11:08:27 pm »
Ok if i was to turn it the other way round how do
I bolt the perch to the underside of the car? Does it go through the boot floor?
Instagram- airz182
Offline Wardy91-ed30
« Reply #6038 on: March 15, 2014, 11:10:12 pm »
Today I upset my mate in his 350bhp classic scoob, all good fun :evilgrin:
« Reply #6039 on: March 15, 2014, 11:15:55 pm »
It's your spring and adjuster the wrong way around not the shocker just turn the spring and adjuster around
Offline Airz182
« Reply #6040 on: March 15, 2014, 11:22:12 pm »
My adjuster has a bolt that goes into the middle of it to hold it in place, as it is at the min it goes through the hole in the lower control arm then into the threaded adjuster bit,
So if i was to flip the other way round where would the bolt, bolt through?
Instagram- airz182
« Reply #6041 on: March 15, 2014, 11:26:41 pm »
That whole threaded part comes out as one whole unit just drop the arm pull the lot out and flip it around. What make are they ?
Offline Airz182
« Reply #6042 on: March 15, 2014, 11:29:12 pm »
Fk's mate
Instagram- airz182
« Reply #6043 on: March 15, 2014, 11:40:34 pm »
Ah that explains it then carry on  :signLOL:  my mistake  :signLOL:
Offline jaffa
  • -Receive: 44
« Reply #6044 on: March 15, 2014, 11:42:00 pm »
My FK's are fitted the same only takes 20 mins to adjust them and change the wheels
Just make sure you put some copper grease on the bolt as it can sometimes stick and spin the whole adjuster
Or just remove the bolt like I have
