Author Topic: What did you and your MKV do today?  (Read 2816133 times)
Offline mrvertigo73
« Reply #7125 on: October 18, 2014, 10:03:24 pm »
Changed the cam follower... good job too as it was looking spent... also new rubber grommets on engine cover and new air inlet screws, which I promptly lost one of as I was putting the cover back on...  :sad1:
If you do not mind me asking, is that a expensive part to replace, and why does it need replacing?
Don't mind at all @wayneitb but you'll find LOADS of info on it on this forum and others. AFAIK the cam follower is "pushed" by the camshaft tappets, which in turn pushes the fuel pump spring. Essentially it's all to do with timing of your fuel / air mix, and because it comes in to contact with your camshaft millions of times in it's life (and with a pretty big whack each time) it's prone to failure. Worst case scenario: f*%k your engine, although unlikely. It's cheap to buy a replacement and quick and easy to fix (even I could manage it, so it must be easy!) so why not? Just make sure everything goes back right, and remember to prime the fuel lines afterwards. I know I shouldn't point out of this forum, but the easiest to follow guide I found was here: http://www.golfmkv.com/forums/showthread.php?t=102858
Good luck
How did she know?
  • -Receive: 427
« Reply #7126 on: October 18, 2014, 10:50:41 pm »
Herd you go, in the "How to" section....
~~ Clicky here ~~
Offline callis
« Reply #7127 on: October 19, 2014, 08:43:11 am »
replaced rear discs and pads :)
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #7128 on: October 19, 2014, 12:07:35 pm »
Front tyres (Pirelli P7 Cinturato) after 26k miles/12+ months where down to 2.5mm and loosing a bit of pressure so replaced them with some Goodyear Eagle F1s to match the rears. Way too early to comment on difference but there is a slight increase in road noise but suspect that is due to increase in tread depth.
dansmith180
« Reply #7129 on: October 19, 2014, 07:32:49 pm »
Took it for a nice drive and gave it a wash.
Offline marko
« Reply #7130 on: October 19, 2014, 08:20:43 pm »
Loving them wheels mate...
dansmith180
« Reply #7131 on: October 19, 2014, 09:01:40 pm »
Cheers  :happy2:
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #7132 on: October 20, 2014, 04:27:39 pm »
I adjusted the bump stops on my boot pop mod as id forgot to twist them out when i fitted it a few weeks ago  :stupid: & now it works perfect  :pomppomp: :laugh:
Offline Pikey Motorsports
« Reply #7133 on: October 20, 2014, 05:38:30 pm »
gave her a clean
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline Tonygti
« Reply #7134 on: October 20, 2014, 08:28:41 pm »
Offline Alex157_gti
  • VCDS 2015 Edition
  • My Ride: Focus ST
« Reply #7135 on: October 22, 2014, 02:34:24 pm »
new key programmed by the AA great service and nice guy!!
2005 Gti Black 18" monzas, full leather, sunroof, sat nav, heated seats. highline, high spec
Sheffield.
VCDS 2015 Edition Hex+Can Can help out
Offline PT82
  • -Given: 19
« Reply #7136 on: October 22, 2014, 06:24:54 pm »
Fitted a mk6 Polo aerial. Much better looking.
Offline Wash
« Reply #7137 on: October 22, 2014, 06:35:32 pm »
Changed the front pads and had a quick look under the car whilst it was on the ramp to find the driveshaft bolts had worked themselves loose along with the bolt holding the dogbone mount in. Had to tap a new thread into the gearbox after stripping the original threads :(
Sent from my SM-G900F using Tapatalk
Offline bbfb10
« Reply #7138 on: October 23, 2014, 12:21:05 pm »
About to head to Midland VW in Cannock to get my Highline clocks fitted and coded.  :happy2:
Full VCDS Hex + Can.
Offline P3T3R
  • 05 GTI, R-Tech stage 1
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,82245.0.html
« Reply #7139 on: October 23, 2014, 08:26:14 pm »
Fitted my evoms intake, so now it sounds like darth vader, also put some new spark plugs in. Can't wait to get to R-Tech for my remap  :party:
