Author Topic: What did you and your MKV do today?  (Read 2813494 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=berhd6d2ski8bml0p6q6kl2r58&/topic,19740.0.html
« Reply #7905 on: March 04, 2015, 06:42:42 pm »
Throw it
Offline Jarre
« Reply #7906 on: March 04, 2015, 07:44:43 pm »
Okay cheers :)
Candy White ED30 :)
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #7907 on: March 04, 2015, 10:05:51 pm »
Bought and fitted the Rev R PCV. Also bought a n/s door mirror as the glass just popped off this morning, £36 later fitted it. Also ordered in Millers Nanodrive for the cars 6000mi service
Can I ask where you got the mirror from? My drivers side glass wobbles at speed, so I don't think it will be long before it drops out :signLOL:
Get a bit of silcone or no more nails on it before you lose it and save yourself a few quid  :happy2:
I'll definitely give it a try, thanks  :happy2:
It's a common enough problem, did this to mine two years ago and still going strong, just don't use too much, or you block the heated mirror element  :happy2:
I would of kept it and glued it back on. But mine chipped on the corner of impact
Offline wesrev87
« Reply #7908 on: March 04, 2015, 11:29:31 pm »
Got some silicon, so may do this at the weekend :grin:
Offline Scott73
« Reply #7909 on: March 08, 2015, 02:25:25 am »
Picked up my 07 white GTi, to say I'm pleased would be an under statement :laugh: :jumping:, cant stop driving it  :driver:
Offline Neil 54
« Reply #7910 on: March 08, 2015, 08:38:29 am »
Fitted new OEM coil packs and plugs
Sun is shinning so off for a drive   :smiley:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #7911 on: March 10, 2015, 02:37:02 am »
This could be a really stupid question, this is my cam follower I removed, is it worth keeping and using again for a few thousand miles once my other one has worn through or just get rid?
I would always choose to replace them because you have already done the work getting at it. I would also note the mileage and determine whether or not to exceed or equal the mileage for the next replacement interval. You must be running a stock HPFP...that follower looks to have another 40k miles left on it in a stock HPFP, but no one really knows. A stock hpfp should allow the follower to run a minimum of 80k miles.
Offline GTIEagles
« Reply #7912 on: March 10, 2015, 09:14:44 am »
It's in the garage getting the outer CV boot replaced, clutch bled and diagnosing why the offside rear brake is binding.
Offline bbfb10
« Reply #7913 on: March 10, 2015, 09:34:09 am »
Replaced my standard RCD 300 and hazard light switch for a Kenwood DNX 521 DAB and a cherry red hazard switch. Looks SOOOOO much better.
Full VCDS Hex + Can.
Offline raven8472
« Reply #7914 on: March 10, 2015, 04:05:18 pm »
Replaced the 70AH standard battery with a 77AH Varta E44 as recommended. Top service from Tanya.co.uk.
Liam0205
« Reply #7915 on: March 14, 2015, 09:38:03 am »
Lucky for some
Offline bennyx_o
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,91047.0.html
« Reply #7916 on: March 14, 2015, 10:22:33 am »
Nice to see someone is getting around the same consumption as me
Liam0205
« Reply #7917 on: March 14, 2015, 01:30:32 pm »
Built to be driven  :happy2:
Offline bennyx_o
« Reply #7918 on: March 14, 2015, 01:41:49 pm »
My thoughts exactly!
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #7919 on: March 14, 2015, 02:55:02 pm »
Just given the mighty GTI a lovely bath to wash off this weeks road crud - also topped up the oil and hoovered the inside
It is usually about now it starts chucking it down!  :signLOL:
