Author Topic: What did you and your MKV do today?  (Read 2811360 times)
Offline Mana321
« Reply #8265 on: June 09, 2015, 11:37:12 am »
Stage 2+ Remap Booked For The 26th  :grin:
APR Stage 2+ FK Coilovers, Forge Twincooler, Evoms CAI, Rev D dv, Longlife 3" Turboback Exhaust, Loba HPFP, ECS Tuning Dogbone Mount Insert
Offline z00bz
  • OEM+ Black MK5 GTi
« Reply #8266 on: June 10, 2015, 11:30:15 am »
Front and Rear Lights restored and polished + BG 109 Engine flush with Oil and Filter changed  :popcornsoda:
OEM+ Black MK5 GTi
Offline K9
  • VW LifeStyle
« Reply #8267 on: June 11, 2015, 02:32:21 pm »
did a DSG reset via VCDS! Iy's now like a new gearbox from the dealer  :happy2: :driver:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #8268 on: June 11, 2015, 06:48:35 pm »
Dropped the ol' 2007 off for a valve job. It needs a right rear bass speaker...rear O2 sensor...new valve seals...maybe some valve stem guides...and (hopefully not) piston rings.  :sad1:
Offline Rampage
« Reply #8269 on: June 14, 2015, 08:45:26 pm »
Had a great weekend that's deepened my love for my car...
Put some Michelin Super Sports on. The tyre guy said its the first time ever in 16yrs, where the alloys were balanced perfectly and he didn't need to put any weights on it.
Had it machined polished the day before and already had two people stop me and offer to buy it  :laugh:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8270 on: June 14, 2015, 09:01:03 pm »
It looks like piston seal rings in cyl's. 3 and 4 may be shot. Everything is soaked in them including the intake ports and valves. All the exhaust ports looked similarly dry...so it is getting soaked during back pressure and leaching oil into the intake side...and why I was seeing smoke during the coasting and initial takeoffs. This is the general consensus so far between my tech and the valve shop tech. More will be determined after seeing the tolerance results for the 3 and 4 cyl. valve guides, but it appears I will be doing rings in addition to the valve seals and guides.
Offline AIR_CHILLED
« Reply #8271 on: June 14, 2015, 09:37:54 pm »
Fitted some Porsche 986 front calipers today (NQSBBK).
Got an awesome pedal feel straight away and the pads still need bedding in!
I would recommend this mod to anyone.
Thanks to Alex at AKS Tuning for sorted the kit out including wheel spacers, adaptors (DaveB Vagbremtechnic), bolts and brake lines.
Very happy
« Last Edit: June 15, 2015, 07:56:39 am by AIR_CHILLED »
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8272 on: June 14, 2015, 11:39:06 pm »
Ouch :(
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8273 on: June 15, 2015, 05:28:56 am »
Yes...it hurts. But what ya gonna do?
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #8274 on: June 15, 2015, 04:43:01 pm »
Take it on the chin and move on. It happens. You doing anything else while you got it all apart?
« Reply #8275 on: June 15, 2015, 11:21:27 pm »
oil and filter change plus a brake fluid change plus i also changed the spark plugs too
Offline SeyiiOluwa
« Reply #8276 on: June 15, 2015, 11:27:19 pm »
Repaired the intake manifold wiring
Airbag light sorted
Replaced a blown Interior light fuse
Replace faulty boot light
Very happy bunny
« Last Edit: June 15, 2015, 11:30:02 pm by SeyiiOluwa »
Offline SeyiiOluwa
« Reply #8277 on: June 16, 2015, 03:26:25 pm »
My joy was short lived, the emissions light has come back! :(
Can anyone help? I'm getting fed up
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8278 on: June 16, 2015, 05:51:10 pm »
Just replacing the valve stem seals, stem guides, piston rings, and rod bearings. All the bits are only 20% of the total bill...so I didn't want to skip what can be addressed while it is torn apart.
Offline Rampage
« Reply #8279 on: June 16, 2015, 06:13:01 pm »
Previously used the 3M Headlight restoration kit, this time used Autosol to treat the yellowing of my headlights. Smeared it in, left for a few minutes and then rubbed it off with a microfibre cloth.  Worked an absolute treat and only took 15 mins!  :laugh:
