Author Topic: What did you and your MKV do today?  (Read 2807422 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9015 on: March 22, 2016, 10:51:47 pm »
@bbfb10 that's ridiculously cheap I'm so flecking jealous  :doh:
Offline vag
« Reply #9016 on: March 22, 2016, 11:15:37 pm »
Picked my GTI up few weeks ago and have been worried about the oil pump chain as its a high miler and have seen them let go, so i replaced the chain, sprocket and tensioner
Old set up, tensioner was almost maxed out!
New tensioner hardly moved once the locking pin was removed, amazing how much slack the old chain had.
Also swapped out the old door handles as they were annoying me
Old
New
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« Reply #9017 on: March 23, 2016, 06:53:45 am »
Dropped my car off with plush automotive for air ride so I have no car for a week
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline Lyons
  • -Given: 18
« Reply #9018 on: March 23, 2016, 08:09:39 am »
Bought 3 brand new Detroits.
Offline deedaz
  • -Given: 47
« Reply #9019 on: March 23, 2016, 03:58:39 pm »
Got my refurb'd wheels today, after doing somesaults in my head about the colour, I went for the satin black, and I'm happy with the results. I wanted a siliver lip, perhaps next time.
Offline horsemeat
« Reply #9020 on: March 23, 2016, 04:31:24 pm »
:happy2: good job!
I'm ticking towards 97k, think this is worth doing? I'll be dropping the sump soon anyway to replace the oil pickup.
Offline zainster
« Reply #9021 on: March 23, 2016, 05:14:48 pm »
Gave the gti a clean.
Offline Dan_77
« Reply #9022 on: March 25, 2016, 01:34:22 pm »
Changed the fuel pump cam follower, fuel pump is the older type with banjo bolt which is awkward to get to, and spent 20 minutes looking for said bolt after dropping it onto the lower engine, in the paperwork i've got for the car there's no mention of it ever being changed before. Bit of wear but seen worse
Offline AIR_CHILLED
« Reply #9023 on: March 25, 2016, 02:28:24 pm »
Nice catch, that looks nasty especially as the hardened coating is all gone!
What was the mileage on the car?
Mike.
Offline AIR_CHILLED
« Reply #9024 on: March 25, 2016, 02:28:39 pm »
Mike.
Offline Masonfantana
« Reply #9025 on: March 25, 2016, 05:22:14 pm »
Upgraded my interior lighting to LEDs
The driver side footwell was a bugger though
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9026 on: March 25, 2016, 07:28:48 pm »
Could you post your mileage with your post. Those do wear much faster when the coating has gone like that. Mine wear through completely  with the HPFP upgrade within 15k miles. Your next CF should last the same or a bit longer if kept fresh with good oil...but safer to check 10k miles before you double the mileage again.
Offline Dan_77
« Reply #9027 on: March 25, 2016, 07:47:56 pm »
Was going to put the mileage but wasn't sure if it had been changed before , the cars just done 90k. got stacks of invoices with car covering the last ten years for all sorts but not one mention of the cam follower being replaced
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9028 on: March 26, 2016, 11:52:43 pm »
Sounds right for original CF. Anywhere from 80k miles to 120k miles is the range when they can fail completely...so good catch.  They can fail pre-80k or post-120k, but normally the range holds true. :drinking:
« Last Edit: March 26, 2016, 11:54:20 pm by ROH ECHT »
Offline M4T VW
« Reply #9029 on: March 27, 2016, 09:29:21 am »
Yesterday/today. HPFP install and change the cam loeb. The old one was in perfect condition so it can't have been on long. I changed it anyway.
Also installing revo camcoat, Rev G diverter valve and oil and filter change. Then I will have faith in the engine as I don't know a lot of its history.
