Author Topic: What did you and your MKV do today?  (Read 2805623 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9150 on: April 25, 2016, 06:57:42 pm »
Thanks mate, also got bored this weekend so decided to spray the diffuser to get away from the dull plastic look  :happy2:
Got caught arriving at the "Get Off The Couch GTG" Saturday Night.
Heading out to Techtonics Tuning today for a reflash of my GIAC K04 HO tune.
« Last Edit: April 25, 2016, 06:59:18 pm by ROH ECHT »
Offline irish_ram
  • -Given: 200
« Reply #9151 on: April 25, 2016, 07:41:11 pm »
Very nice, car in proper stealth mode  :evilgrin:
Offline irish_ram
  • -Given: 200
« Reply #9152 on: April 26, 2016, 08:34:51 pm »
DSG service and H&R springs finally fitted
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9153 on: April 26, 2016, 09:20:43 pm »
Lights also changed  :driver:
nice drop  :smiley:
Offline irish_ram
  • -Given: 200
« Reply #9154 on: April 26, 2016, 09:35:29 pm »
nice drop  :smiley:
Cheers mate,
yes the last few weeks have been busy with skyline ED30 rear lights back on, new genuine pescaras with Rainsport 3's and finally my H&R springs  :happy2:
Now need a rest me thinks for a while  :grin:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9155 on: April 26, 2016, 10:20:01 pm »
@irish_ram you've done well mate  :happy2:
looks nice too.
need to pull my finger out and fit all the bits and bobs I have as it's been way too long but don't seem to get the time with this new job which I don't think I'll have for long.
anyways my skyline mod is finally ready but just awaiting the dimmer and wiring  :signLOL:
R5
Offline irish_ram
  • -Given: 200
« Reply #9156 on: April 27, 2016, 06:59:56 pm »
looks nice too.
R5
Yes get them fitted mate asap  :wink:
Although I have the skyline mod on my Inners but still have not bothered to wire them up yet as not sure how to do it  :confused:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9157 on: April 27, 2016, 07:09:42 pm »
Courtesy of an r32oc member  :wink:
You will need some Thin Wall 1.0mm² 32/0.20mm loom wire. I ordered 10 meters of each colour so i had plenty. You will get away with thinner wire, however seeing as you are running brake AND tail, thicker is always better/safer.
Now, there are a few ways to do this. You could probably get away with running a single wire to the tail lights, and literally just use a ring connector to bolt the earth to the tailgate somewhere. However I did not go this route. In fact I ended up running 6 cables in total, but you will not need that many.
have a plan in your head on what you want to achieve and go from there. I ran 3 wires to each inner and splced them into BOTH rear lights. That way if I blow a fuse etc I will only have 2 lamps go down rather than 3 out of the 4. Hope that makes sense.
Anyway, if you go for the single wire way, connect your earth wire to a good earth point on the tailgate, ideally one for each inner. Then connect the feed wire to both inners and run it down the passenger side rubber boot on the tailgate/body. Pick up the wire the other side and feed it down the C pillar. At this point it's easier to remove the trim down the C pillar and boot. Feed the wire down paralell to existing wiring until you get to the tail light.
Here's the tricky to describe part. Depending on what effect you want, you will need to do some pin swapping. For the quad light (skyline) effect, remove the black/red (black/purple on the drivers side) pin from it's connector and splice your wire to the inners to this. Now remove the thinner wire (not sure on colours) in pin 3 position and put pin 2 in it's place. You should now have side lights and brake lights on your inners.
The wire that is still out of the connector is your tail light wire and you have a couple of options. 1. Tape it back (will bring the bulb out error on the dash). 2. fit a 6 ohm resistor in place (what i have done, will remove bulb out error). 3. Connect it to pin 2 position (will light the centre of the outer lights up when lights are on).
Now, depending on how OE you want this to look, you can run more wires (2 from each inner) the same way and connect them to each tail light. Or you can leave it as a single wire feeding both inners.The brown wire is earth, so you can splice into that if required.
As my SMD conversion uses indicators i ended up running 6 wires through the tailgate (3 wires per inner) and picking up earths at each outer light. Also, doing it this way should not require any VCDS programming, although you can have a play with the brightnesses etc if you want.
Hope that helps.
Kris
Offline irish_ram
  • -Given: 200
« Reply #9158 on: April 27, 2016, 08:05:49 pm »
Hope that helps.
Kris
Thanks but that has scared me to be honest.
I got sent the inners with 2 wires a black and a red coming out of each inner and was informed I just need to wire each inner to the number plate light which I presume they mean the red wire and the black wire just need earthing somewhere
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9159 on: April 27, 2016, 08:33:50 pm »
Lol it is quite confusing to me too  :rolleye:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9160 on: April 28, 2016, 03:51:56 pm »
Finally fitted my cam follower and GFB dv+ in on lol
what a pitta on both parts to fit so novices beware and don't try it if you're not competent enough or have a decent set of tools to hand as you'll regret it by screwing the banjo bolt and then having to go to a garage to remove it unless you wish to chisel it off  :signLOL:
DV has seen better days so all the boosting issues are finally gone not that I knew I had any but car feels super responsive now though  :grin:
Oh and the alarm siren is meant to be on the near side but here it is on the driver side for anyone who is looking for it.
« Last Edit: April 28, 2016, 03:58:13 pm by r5gtt »
« Reply #9161 on: April 28, 2016, 04:01:32 pm »
DV+ is a piece of cake on K04 cars  :smiley:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9162 on: April 28, 2016, 04:08:07 pm »
YES thanks for rubbing it in further @Pudding
I know it's at the blasted front and takes a couple of minutes to do  :slap:  :signLOL:
« Reply #9163 on: April 28, 2016, 04:20:52 pm »
Hehe!  Good bit of kit that DV+ though  :happy2:  I like the little squeak it does at part throttle when you lift off.  Apparently you can tune that out by omitting one of the parts, can't remember which.   I defo don't get any more turbo chuntering with the DV+, so it does a good job!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9164 on: April 28, 2016, 04:54:57 pm »
Ive not fully test drove ot as id lose my parking spot but let friday come  :driver:
I'm thinking if I need to move to a new rev solenoid as that one did look dated and most likely from factory. :thinking:
