Author Topic: What did you and your MKV do today?  (Read 2744725 times)
Offline Rado16v
« Reply #9645 on: August 20, 2016, 02:33:36 pm »
Finally got round to replacing the cam follower, pcv and dv on our 57k mile edition 30. They didn't need it however but I had the bits.
Did the front brakes and started the rears but thought no chance getting those carrier bolts off so will have it booked in for that.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9646 on: August 20, 2016, 09:42:08 pm »
Fitted both my ED30 front and rear valances ans they look good  :jumping:
Bad points are rear arch liners were a pain to fit to the new locating holes under the rear wheels and front needs a little triming but no time for that shi** so I'm a leave it as is. Also front needs to really be screwed in where the oem lugs fit as it's kinda loose.  will do that when the bumper comes off for the R6 IC  :smiley:
« Last Edit: August 21, 2016, 10:27:05 pm by r5gtt »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9647 on: August 21, 2016, 12:35:35 am »
Boost looks low too!
Hey there John Hurdy, it is 21 psi now...normal for GIAC K04-HO tune here in the states. I quit running the DriverMotorsport K04+ tune. It was 25 psi but never beat my 1/4 ET of the GIAC tune and I had to rebuild the engine last year because of rings pinched in the piston grooves. I thought it safer to reduce the boost  :smiley:
My biggest issue is finding the cause of the fuel pressure. GIAC doesn't want to send me an improved stronger tune, having IE connecting rods now, until they see this corrected...and I don't know what to do other than a new hpfp w/internals next.  :sad1:
« Last Edit: August 24, 2016, 07:12:23 pm by ROH ECHT »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9648 on: August 27, 2016, 06:23:38 pm »
VIS MOTORSPORT HPFP fitted today  :smiley:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9649 on: September 02, 2016, 11:50:24 pm »
Cleaned the Neuspeed p-flo filter and soaked the MAF sensor for 20 minutes in isopropyl alcohol. Recharged the filter with K&N oil and allowed the MAF to dry for 1 hour...then put it all back together.
« Last Edit: September 03, 2016, 12:42:23 am by ROH ECHT »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9650 on: September 03, 2016, 12:18:58 am »
Fitted my R8 coil packs and hpfp protection cover  :grin:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9651 on: September 03, 2016, 12:43:56 am »
Interested in knowing more about the hpfp protective plate? Looks great...but why?  :drinking:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9652 on: September 03, 2016, 12:49:10 am »
Thanks buddy, the reason why is because I still run with the box cover and read many posts of the hpfp sensor on the top breaking so had to buy one for safety precautions. Ordered a CAI as I'm fed up with that ugly box now so here comes a Ramair CAI  :smiley:
Offline GTI8v
« Reply #9653 on: September 03, 2016, 11:22:10 am »
I'd be more interested in one that covers the N75, (top right) I'm scared of removing the engine cover now in case I break the sodding connector off again! A big 5mm thick stainless cover should protect it from my ham-fistedness  :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9654 on: September 03, 2016, 11:57:39 am »
huh? @GTI8v  you lost me at N75 which is located on the turbo right hand side behind the arch liner.
Offline GTI8v
« Reply #9655 on: September 03, 2016, 12:18:29 pm »
@r5gtt Apologies drinking tea, eating cake and reading, should do one or the other.
Top right of your photo, and I meant N205. what a dick.  :doh: :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9656 on: September 03, 2016, 12:27:35 pm »
No worries as I though I was going mad :stupid:
That sensor will be fine as the cover is higher internally at that end  :happy2: @GTI8v
Offline Mark_DF05
« Reply #9657 on: September 03, 2016, 02:37:25 pm »
Got hit by a large stone on my way to work, dented my wing and took the paint off so booked into the bodyshop for repair :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0dbamcag8qocj20kp2li324455&/topic,90967.msg917089.html#msg917089
« Reply #9658 on: September 03, 2016, 02:51:51 pm »
Treated her to a quick wash and wax today as she should hit 100k next week.
05 | Tornado Red | DSG
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #9659 on: September 03, 2016, 05:55:38 pm »
Ahh...I ran mine for some time with the cover modified after adding the intake:
...but I tossed out the cover a couple of years ago because tired of it :happy2:
