Author Topic: What did you and your MKV do today?  (Read 2743520 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9810 on: October 17, 2016, 07:10:26 pm »
My oil pressure light came on during a hard drive. I then dropped the sump and my pickup pipe had small pieces of hard plastic in it (tensioner breaking up). I didn't want to risk changing it myself so got my local VW specialist to do the chain and tensioner.
Were these replaced as well? If oil pressure problem returns...look into the condition of these inside the cam-tensioner cover. https://www.ecstuning.com/ES2726697/?gclid=CjwKEAjw5pKtBRCqpfPK5qXatWYSJABi5kTxAEu3Fro_PDcaoBk1JN-5rCM1m1FuG671w5eFAzatuRoCb3Pw_wcB
They are known to fall apart and create noise and pressure issues. They are somewhat rigid and possibly why they do eventually come apart. I feel worth renewing any time, and for any reason, the cam adjuster cover must be removed.
No I didn't, I used a parts list on the guide that's on here but I would have if I would have known before... Saying that it seems perfect and I'm pretty sure the oil pressure light came on only due to a large piece of the tensioner temporarily blocking the strainer on the pick up pipe. I'm going on a 250 mile journey at the weekend, that should be a good test for whether everything is okay.
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #9811 on: October 17, 2016, 11:21:31 pm »
Fitted Genuine ABS Repair Kit to cure G201 Pressure Sensor Fault, Brake Fluid Change using Pagid DOT 4 and Pre-Cat removal.
Offline Bignod00
  • Ginsters are sh*tE!!
« Reply #9812 on: October 18, 2016, 06:17:21 pm »
Got the ASBO back from her 4WD conversion and safe to say I'm happy. :innocent:
Check my build thread if you're interested so I don't spam this one with loads of pictures! :happy2:
Offline CosmicGTI
« Reply #9813 on: October 18, 2016, 09:46:26 pm »
Gave my Ed30 a clean and did the engine bay while I was at it
Car looks lovely! Good job with the engine bay! Have you had your wings replaced under warranty or something mate?
Offline 99hagued
« Reply #9814 on: October 19, 2016, 12:24:25 am »
Cheers mate  :happy2: yes had them done last year is the paint difference that obvious
Offline golfmck1980
« Reply #9815 on: October 19, 2016, 12:04:43 pm »
Car on the road a week and back in the mechanic the rear passenger door is bollocked the window dont work the lock the lock dont work and now the door handle is about to fall off. So much for changing the headunit this month.
Stupid VW build quality
Edition 30 num 859
Offline Tanuie
  • -Given: 36
« Reply #9816 on: October 29, 2016, 11:18:25 am »
Just changed both front grills and the fog light surrounds as the old one's looked a bit discoloured, what a PITA.
MPS
« Reply #9817 on: October 29, 2016, 12:46:32 pm »
Did you manage to remove your GTI badge without breaking the clips? I didn't.  :sad:
Offline Tanuie
  • -Given: 36
« Reply #9818 on: October 29, 2016, 01:08:36 pm »
Didn't have to remove the GTI badge, so still intact.
Offline ducman77
  • -Given: 59
« Reply #9819 on: November 05, 2016, 10:34:44 am »
Just had this bad boy delivered. Now I have to fit it (hopefully next Friday!)
Offline golfmck1980
« Reply #9820 on: November 05, 2016, 10:44:36 am »
Woke up this morning to find the driveway still empty forgot wot it was like to have the golf cause its been in the mechanics so bloody long
Edition 30 num 859
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #9821 on: November 05, 2016, 11:00:33 am »
How much is the peron? And is it a direct fit no modding required?
Offline ducman77
  • -Given: 59
« Reply #9822 on: November 05, 2016, 01:55:42 pm »
I paid £590 from AKS then I saw sico developments are doing them for £550. Comes with all the pipes, clips, bolts to fit it. I believe there's some trimming Required to fit. Will report back after Friday. Wish me luck!!
Offline slix
  • -Receive: 38
« Reply #9823 on: November 05, 2016, 02:57:45 pm »
Okay thanks. Is it thicker than the stock one by much?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #9824 on: November 05, 2016, 04:48:50 pm »
Are you k03 or k04?
