Author Topic: What did you and your MKV do today?  (Read 2822008 times)
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #9960 on: December 17, 2016, 01:05:18 pm »
Here's my cam follower, 70k on the clock.
Scratches on the follower look worrying
I'd check the camshaft properly for wear too
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #9961 on: December 17, 2016, 01:19:43 pm »
It looked ok bud, just didn't have my phone on me to take a pic, and they're not really scratches, it's quite smooth.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4jk56dg8j377s258haptk49h96&/topic,90967.msg917089.html#msg917089
« Reply #9962 on: December 17, 2016, 03:21:18 pm »
70k that looks like 100k
That one looks good, i'm yet to see one worse than mine.
05 | Tornado Red | DSG
Offline Lewo
« Reply #9963 on: December 17, 2016, 03:43:21 pm »
Wow, top job :laugh:
Cheers, that 3M kit really could not make it any simpler!
If I didn't balls it up anyone could do it!
Did you use just the one kit for both lights?
Yes it does.
Offline Kai96
« Reply #9964 on: December 17, 2016, 05:16:25 pm »
Washed and dried, managed to get a layer of sealant on. headlights were machine polished as they were looking abit hazy (forgot to get a pic of them) and machine polished my B pillars as they looked terrible with all the swirl marks and scratches.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9965 on: December 18, 2016, 12:32:45 am »
Today I got the parts that I recently bought fitted:
-Celtemp HPFP protection shield
-VW Racing intake for K04
-Custom painted TTS engine cover
-VW Racing adjustable front drop links
-Go Fast Bits lightweight crank pulley
I didn't take a picture of the GFB crank pulley but it's much lighter (1,4 kg) than the OEM part. It comes with 6 new bolts. :smiley:
The included bolts had different sizes. One was too long and the other was the same size as the OEM bolt. So I kept the OEM bolts and I'll make a complaint to Celtemp. :fighting:
The closed cone bracket on the grill had to be trimmed a bit due to the larger IC so that the bolts could be screwed. Other than that all fitted nicely. :smiley:
Final result! The engine bay is a bit black but it contrasts with the white car. I like it! :grin:
Both factory drop links were ruptured so it was a good call to get them replaced with better parts now. :smiley:
So far I'm liking the new engine sound. It has a deeper roar a bit louder than before. It makes me want to boost the engine more often so the louder sound is exciting. :driver: It's quiet on normal driving which was also something I was looking for. :smiley:
The engine seems to rev better on higher rpm and the butt dyno is happy with the new intake. I hope when I get the car dyno tested again the result is better too. :smiley:
Offline Lewo
« Reply #9966 on: December 18, 2016, 01:57:10 pm »
Like that intake.  :happy2:
Pricey I guess....?
What's the idea of the guard?
« Last Edit: December 18, 2016, 02:01:47 pm by Lewo »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9967 on: December 18, 2016, 04:01:04 pm »
Pricey I guess....?
So far I'm liking it a lot. I bought it on the Black Friday sale.
The shield protects the fuel pump sensor which wasn't cheap.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9968 on: December 18, 2016, 04:19:16 pm »
hi mate, looking real nice  :happy2:
how have you set your adjustable drop links?.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9969 on: December 18, 2016, 06:15:24 pm »
They were shortened about 30 mm compared to the OEM ones, since I have H&R-30 mm springs. Both were set at the same length.
Offline barelyrelevant
« Reply #9970 on: December 18, 2016, 06:52:10 pm »
Your headlights look great, makes me realise how much mine could do with being sorted out. Did you just use a cutting polish or did they need wet and dry sandpaper?
Offline Lewo
« Reply #9971 on: December 18, 2016, 07:27:05 pm »
Pricey I guess....?
£? on both?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9972 on: December 18, 2016, 08:00:38 pm »
I also have 30mm H&R full suspension and adjustable roll bars so thinking will I need to adjust my white line links to accommodate and how much will I need to screw them in/out  :thinking:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9973 on: December 18, 2016, 09:31:04 pm »
Pricey I guess....?
£? on both?
The VWR intake was £369.20 and the protection shield 44,95 €. A LOBA HPFP costs £620 nowadays, I think. I prefer to make sure nothing bad happens to it. :wink:
Offline spwd
  • Hello I'm Steve.
« Reply #9974 on: December 18, 2016, 09:56:23 pm »
What wheels you got on Kai, any pics?
