Author Topic: PCV  (Read 2447 times)
Offline bird752
PCV
« on: June 12, 2011, 10:31:02 am »
Would a faulty PCV cause the exhaust emissions light to stay on permanently?  Trying to get rid of mine and so far I have had the inlet manifold runner control changed and the PCV is next.  Any one an idea how much these cost and would I notice a difference when it is changed (apart from the extinguished light I hope!).
Re: PCV
« Reply #1 on: June 12, 2011, 10:34:37 am »
Stop!
Before you go changing anything else, go get the car vcds scanned to see what the stored fault code refers to...  :smiley:
Offline bird752
Re: PCV
« Reply #2 on: June 12, 2011, 04:31:21 pm »
Fault Code is 08583 P2187 Bank 1 Fuel Measuring System Too Lean at idle.
Re: PCV
« Reply #3 on: June 12, 2011, 05:07:00 pm »
h4rdy
Re: PCV
« Reply #4 on: June 12, 2011, 05:09:47 pm »
Do you have a remap by any chance and if so which one?
I bet I know if you do!
Offline bird752
Re: PCV
« Reply #5 on: June 12, 2011, 08:35:54 pm »
Had a look through the check list and to be honest, i aint got a clue how to fix stuff like that!  As for a remap, I take it you mean has it been modded in any way?  Answer is no, not since Ive had it and I dont think it has before that (anyway of checking this?).  Sorry to be a pain guys but I would like my car to be fixed without spending a lot of wonga.
Offline chowgar
Re: PCV
« Reply #6 on: June 12, 2011, 09:02:13 pm »
is that possible :confused:
h4rdy
Re: PCV
« Reply #7 on: June 12, 2011, 09:35:46 pm »
Too lean at idle does point kind of to PCV.
You could, I have no idea if this is the done thing you do so at your own risk and if anybody else says no then its no but its what I did, take the engine cover off and remove the PCV connection pipe from the PCV. Its the one that sits in between the PCV and the intake manifold. I just got some Duck tape and placed it over the PCV outlet to intake and refitted the pipe back on. You have effectively sealed off any leaks to the inlet which is what a PCV fault causes.
Put the cover back on and everything else.
Start the engine and let it idle.
Turn off, plug VCDS in and clear all your faults.
Drive about or whatever and see if the Lambda fault comes back on.
THERE IS A CHANCE I COULD GET SHOT DOWN FOR THIS PROCEDURE BUT, NOT BEING A BILLY BIG B******S, I CAN WORK THINGS OUT FOR MYSELF AND KNOW THE RISKS. IF YOU CHOOSE TO TRY IT DO SO AT YOUR OWN RISK. I WILL NOT BE HELD RESPONSIBLE FOR A BLOWN ENGINE OR WORSE A TRIP TO HOSPITAL. IT WORKED FOR ME TO DIAGNOSE A FAULT I HAD.
If it works get on to Dubtek and buy a PCV deletion kit for £70 or even better a BSH catchcan.
