Author Topic: Gti dump valve  (Read 17942 times)
Offline Fizgti
Gti dump valve
« on: June 12, 2011, 05:44:01 pm »
Help needed!
Im after a dump valve for my golf gti been looking around and was after some advise about which one to go for?
Anybody had one fitted?
Offline alexperkins
  • -Receive: 99
Re: Gti dump valve
« Reply #1 on: June 12, 2011, 05:47:53 pm »
The GTI, if its a Mk5 does not have a dump valve. It has a diverter valve instead.
Offline Fizgti
Re: Gti dump valve
« Reply #2 on: June 12, 2011, 05:56:06 pm »
Is it? I spoke to guy on fleebay said forge make one for the 2.0 fsi turbo? Just want that extra sound it?
Yh it is a mk5
Offline alexperkins
  • -Receive: 99
Re: Gti dump valve
« Reply #3 on: June 12, 2011, 05:57:39 pm »
They do make a DV (diverter valve) and they also make a spacer which spaces out the DV to make more noise
If you want more noise, get the forge spacer
Offline Fizgti
Re: Gti dump valve
« Reply #4 on: June 12, 2011, 06:06:02 pm »
Ok any ideas where from?
Offline alexperkins
  • -Receive: 99
Offline Fizgti
Re: Gti dump valve
« Reply #6 on: June 12, 2011, 06:12:05 pm »
I see its my first turbo you see wanted to hear the sound, are they hard to fit?
Offline alexperkins
  • -Receive: 99
Re: Gti dump valve
« Reply #7 on: June 12, 2011, 06:13:18 pm »
If its a normal GTI, takes an hour or so as youll have to get behind the engine via the drivers wheel arch to remove the DV and put the spacer in between
Offline Fizgti
Re: Gti dump valve
« Reply #8 on: June 12, 2011, 06:13:55 pm »
Also do you have to buy the diviter valve to fit the spacer?
Offline alexperkins
  • -Receive: 99
Re: Gti dump valve
« Reply #9 on: June 12, 2011, 06:14:59 pm »
No. The engine already has the DV fitted to it mate. The spacer just goes in between
Offline Fizgti
Re: Gti dump valve
« Reply #10 on: June 12, 2011, 06:15:39 pm »
Thanks for help will order off fleebay tongt
Offline alackofspeed
  • -Receive: 24
Re: Gti dump valve
« Reply #11 on: June 12, 2011, 10:55:04 pm »
If you jack up the car, and slide under it, you can easily reach the re-circ valve, and change it / add a spacer. It took me about 15 minutes to change my car's valve.
Offline Jussa
  • Bicester
Re: Gti dump valve
« Reply #12 on: June 12, 2011, 11:05:46 pm »
Offline Fizgti
Re: Gti dump valve
« Reply #13 on: June 14, 2011, 07:33:34 pm »
Yeh i havent ordered it yet some people were saying that it messes with the engine and that lights start to come on so im still thinking about what to do?
Re: Gti dump valve
« Reply #14 on: June 14, 2011, 07:37:14 pm »
Used forges spacer for 2 years.  Doesnt bring up any EML Lights or faults.  They wouldnt sell it otherwise  :happy2:
