Author Topic: In tank pump?  (Read 3130 times)
Offline s3dubbin
In tank pump?
« on: June 14, 2011, 06:34:17 pm »
Can i get to the 2nd fuel pump from here? Can somebody point it out to me or explain where to get to it? Cheers, Stevie.
Re: In tank pump?
« Reply #1 on: June 14, 2011, 06:35:51 pm »
Its meant to be a bit of an arse to fit.  I was after the uprated in tank pump.  Was quoted £200 fitted
Re: In tank pump?
« Reply #2 on: June 14, 2011, 06:36:29 pm »
P.S I believe OwenLcr has done it himself  :happy2:
Offline s3dubbin
Re: In tank pump?
« Reply #3 on: June 14, 2011, 06:38:57 pm »
Where is it mike? Can i get to it from that pic? I have met owen a few times at crail will look out for him. Stevie.
Re: In tank pump?
« Reply #4 on: June 14, 2011, 06:40:57 pm »
Sorry Im not sure.  Steve at Statlers will probably be doing mine...
Do you have an uprated pump?  If so and you manage ok Id consider doing my own too
Offline s3dubbin
Re: In tank pump?
« Reply #5 on: June 14, 2011, 06:49:24 pm »
No probs. Hopefully some more people will get involved. Got the hpfp and done it myself taking my time and keeping everything clean didnt have any problems. Stevie.
Re: In tank pump?
« Reply #6 on: June 14, 2011, 06:52:00 pm »
But are you planning the uprated intank fuel pump?
Offline s3dubbin
Re: In tank pump?
« Reply #7 on: June 14, 2011, 06:56:24 pm »
Yes i will go ahead with the in tank pump. Unless somebody in the know comes along and point blank tells me no chance do not try. Cant see it being too difficult.
Offline yin
  • -Given: 77
Offline s3dubbin
Re: In tank pump?
« Reply #9 on: June 14, 2011, 07:05:07 pm »
That is spot on Yin. Thank you.  :happy2: Get it done Mike!
Re: In tank pump?
« Reply #10 on: June 14, 2011, 07:06:53 pm »
Which pump have you bought? Where from/How much?
Many thanks!
Offline s3dubbin
Re: In tank pump?
« Reply #11 on: June 14, 2011, 07:38:37 pm »
Engine pump? Autotech...many moons ago i cant remember how much. In tank seems to be the bosch i think? I will contact KMD and see if they can help me out. I have probably done the hardest part by removing the seats. Stevie.
Re: In tank pump?
« Reply #12 on: June 14, 2011, 07:40:47 pm »
Right.  When I spoke to Statlers they said it was a pain of a job, perhaps not.  Think I remember Owen saying he had to drop the tank some?
Offline s3dubbin
Re: In tank pump?
« Reply #13 on: June 14, 2011, 07:51:24 pm »
Golfmkv write up seems quite easy. Usp are doing them for $240.
Offline yin
  • -Given: 77
Re: In tank pump?
« Reply #14 on: June 14, 2011, 07:55:10 pm »
Dan off Vagoc runs the USP might be worth emailing him
http://vagoc.co.uk/vb/member.php?u=103
