Author Topic: passenger airbag not plugged in?  (Read 1059 times)
Offline karl210
« on: June 15, 2011, 02:38:34 pm »
I bought my car as a repaired catagory D write off, everything seemed fine to me, i did notice the airbag light flashed saying it was off but i thought this was just beause the key was in the off position, anyway after switching it to the on position it still does it. yesterday i removed the dashboard end cover and noticed its unplugged. Any ideas on whether i should plug it back in? get it checked out or just leave it? i dont fancy replacing the dashboard because i just plugged it in without thinking, obviously i know to disconnect the battery for 30 mins to let it discharge but if theres a problem it will blow anyway when i connect the battery, help, cheers
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: passenger airbag not plugged in?
« Reply #1 on: June 15, 2011, 04:31:06 pm »
I'ts a tough call to be honest.
Does it look like it's been previously activated - that would be my first thought.
Stu...
Offline karl210
« Reply #2 on: June 15, 2011, 04:45:22 pm »
Hard to tell really, dash seems secure with no signs that its been replaced. There is something thats cracked in the engine bay, has a new rad and the top slam panel must be off a gti with aircon as my car doesnt have aircon and it has the refridgerant sticker on if you get me? it also has a gti kit fitted so not sure if that is needed for the gti bumper or it has had a decent front end whack, my car is a non gti by the way.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: June 15, 2011, 10:32:58 pm »
I think you'll probably need to think about getting another airbag then to be honest.
Have you checked with VCDS and see if the crash sensor has faults logged?
Stu...
Offline karl210
« Reply #4 on: June 16, 2011, 02:01:58 pm »
nope, if that will show it up then i'll have a look on the register and see if anyone is willing to have a look for beer tokens, cheers
