Author Topic: Couple of questions... Rear hubs, vwr bottom mount...  (Read 1738 times)
« on: June 21, 2011, 09:26:47 pm »
Who has painted the centre of the rear discs?  What paint did you use?  Saw some Hammerite spray on fleabay but havent seen anything like it over here in Germany.
Also whats the lifespan on the VWR lower mount?
Thanks in advance!
Re: Couple of questions... Rear hubs, vwr bottom mount...
« Reply #1 on: June 22, 2011, 01:46:34 pm »
So the brake discs are masked up ready for painting...
Cant find a spray hammerite type paint over here.  I reckon normal paint wouldnt take without primer or would chip easier???
Anyone?
Offline johnboy07
« Reply #2 on: June 23, 2011, 08:20:03 pm »
ive used hammerite on my fronts and rears on the centre parts but only the top edge not the front where the wheel buts up to. But then you wouldnt see that anyways so stupid to point that out  :signLOL: :rolleye:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
« Reply #3 on: June 23, 2011, 08:45:25 pm »
Did you use normal hammerite with a brush or find a hammerite spray?  Cant find anything like it over here in Germany :-(
Offline gazbutS3
« Reply #4 on: June 23, 2011, 09:55:34 pm »
you need high temp paint really Mike
« Reply #5 on: June 23, 2011, 09:56:34 pm »
I first thought that but then thought the rear hubs probably ont get that hot??
Offline mb
  • -Receive: 29
« Reply #6 on: June 23, 2011, 11:05:39 pm »
[/quote]
I used Hammerite with a brush on mine.
Offline johnboy07
« Reply #7 on: June 24, 2011, 07:24:30 am »
i did use normal hamerite but i didnt see the high temp paint so i would use that if i did it again as you would be surprised how much heat can build up :happy2:
