Author Topic: Golf mk5 2.0tdi low mpg?  (Read 9034 times)
Offline mk5craig
« on: June 24, 2011, 10:25:28 pm »
Hi all, i have tried the search but couldnt find much about mpg on the tdi's,
 i have a 2006 mkv 2.0tdi gt tdi 4mo and fuel economy is crap,i filled the car to the brim and ran it til empty and it worked out i was doing around 33mpg (worked out manually) :surprised:, have scanned with vagcom and nothing, thinking Maf could be gone?
any advice would be greatful
thanks craig
Offline mortygttdi
  • -Receive: 146
Re: Golf mk5 2.0tdi low mpg?
« Reply #1 on: June 24, 2011, 10:31:59 pm »
Craig if this is round town driving then its about right, the 16valve BKD diesel engine is not has frugal has the older PD engine but it feels smoother
It does seem to come into its own when on longer journeys.
Darren
Offline barratt
« Reply #2 on: June 24, 2011, 10:40:08 pm »
I've got the same problem on my 1.9 BXE (which is mapped). It's strange though, as mine started when the weather started getting warm about a month ago. It hit 27 degrees one day and ever since its been as bad as a petrol. Full WOT in 2nd achieves 9mpg on the instantaneous meter.
I found something on another forum where people were doing tricks to reset the ECU which helped people. Basically pulling the battery for X amount of time. Another was put the ignition on and hold down the accelerator for 10 seconds or 10 minutes (can't remember which). I attempted the accelerator one which helped a little, I can't get it down to 9mpg again but it still goes as low as 12 :(
Not sure if it's worth trying either of those. My average drives return between 38-45(tops)mpg where as It used to be 45 even when constantly hammering it and 50 plodding around.
MK5 1.9 TDI BXE - AET Turbo's Remap - 140hp/325nm - GTTDI Leathers - GTI Headlights - R32 Rear lights - HEX+CAN VCDS
Offline mk5craig
« Reply #3 on: June 24, 2011, 10:47:14 pm »
most of it i was driving sensibly (only had it for a week so still getting used to it) most of it was 12 miles to work which is good roads mainly 40mph and 60mph roads?
will give your methods a go
thanks craig
psw mk5
« Reply #4 on: June 25, 2011, 06:46:21 am »
Seems about right that my mapped 170 only gives high 20's round town but on a run where it can stretch it's legs it gets over 50mpg and I've got 540 to a tank .. Pics to prove in cars for sale section... Shameless plug  :innocent: but needs must  :P
Offline vwdubster77
« Reply #5 on: June 25, 2011, 06:16:13 pm »
Hi,
According to book, the mpg figures for a 2.0tdi 4 Motion is:
Urban:            36.70MPG
Extra Urban:   56.50MPG
Combined:      47.90MPG
A standard 2.0Tdi GT is:
Urban:            41.50MPG
Extra Urban:   60.10MPG
Combined:      51.40MPG
A 2.0GT Sport TDi DSG is:
Urban:            35.80MPG
Extra Urban:   57.60MPG
Combined:      47.10MPG
Hope that helps.
Offline mk5craig
« Reply #6 on: June 25, 2011, 11:24:32 pm »
Thanks for the info, so my car is down quite a bit, im getting about 30-35mpg combined and should be around 47mpg, think i wil log my maf on vagcom and go from there
thanks craig
« Reply #7 on: June 25, 2011, 11:37:29 pm »
around town thats right
Offline mk5craig
« Reply #8 on: June 25, 2011, 11:47:07 pm »
Thats not around town, done several 12 mile journeys on good roads (work) and a couple of 50 mile trips (paintablling,picking the car up etc)
i put in 72quid and got 400 miles so work out 35mpg, will also see how well i get on this tank
« Reply #9 on: June 25, 2011, 11:55:23 pm »
ive got a 170 2.0 tdi and i get around 35-36 around town. stop start sorta thing. on a run with no stopping ill see about 52 ish
