Author Topic: New Suspension & Wheel Setup  (Read 3290 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« on: June 25, 2011, 04:10:53 pm »
Guys,
I want to confirm the following setup is not going to give me any rubbing issues. I've had mixed judgments on it with people away from the forum that I've asked.
2006 GTI 3 door
30mm H&R springs
18x8 wheels with an ET of 35
Regularly have front and rear passengers
Want to continue with the OEM dampers if viable
Will the wheel arch liner mod definitely be required?
Does that mod apply to both the front and back arches?
Pete
Offline edd666999
  • -Receive: 89
Re: New Suspension & Wheel Setup
« Reply #1 on: June 25, 2011, 06:34:13 pm »
225 or 235 tyres?
Offline gazbutS3
« Reply #2 on: June 25, 2011, 06:41:57 pm »
I think you is gonna have some rubbage with the ET35 offset
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #3 on: June 25, 2011, 09:04:14 pm »
225 or 235 tyres?
225 Ed. Would I have to drop to 215's?
« Last Edit: June 26, 2011, 07:48:26 pm by rdfcpete »
Pete
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #4 on: June 26, 2011, 07:49:30 pm »
Okay Gaz  :happy2:
My current Turinis have an offset of ET51 - could I get away with it just about on those?
« Last Edit: June 27, 2011, 06:35:37 pm by rdfcpete »
Pete
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #5 on: June 27, 2011, 06:36:16 pm »
Will an ET of 51 (18x8) be okay with 225/40/18 tyres? I've very little experience with drops on the Mk5  :scared:
Ta  :happy2:
Pete
Offline gazbutS3
« Reply #6 on: June 28, 2011, 07:45:14 am »
Ta  :happy2:
Should be fine with the front arch liner mod  :happy2:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #7 on: June 28, 2011, 05:51:07 pm »
Thanks Gaz.
Front only? Haven't heard it referenced all round... (?)
Pete
Offline gazbutS3
« Reply #8 on: June 28, 2011, 05:53:43 pm »
no problem mate, I thought Turini's in the mk5 fitment were ET42?????
rears should fine mate :happy2:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #9 on: June 28, 2011, 06:23:54 pm »
You're dead right, 51 was the offset for my other Speedline wheels  :scared:
So ET42, does that present a new problem?
Pete
Offline gazbutS3
« Reply #10 on: June 28, 2011, 08:12:55 pm »
They are gonna poke about 15mm more than stock wheels, reckon you should be just about ok as long as you don't go too low, will fill the arches well :smiley:
« Last Edit: June 29, 2011, 08:36:07 am by gazbutS3 »
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #11 on: June 28, 2011, 08:19:59 pm »
I thought it best to check, although I was working on the theory that Mike ran Turinis on his (18x8 & Et42 + 225/40/18) and if I remember correctly his was dropped nicely, 30mm if not lower?  :smiley:
Pete
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #12 on: June 29, 2011, 09:40:29 pm »
Will I get full lock too? I have to use it twice a day without fail. Ta  :happy2:
Pete
Offline gazbutS3
« Reply #13 on: June 29, 2011, 10:53:03 pm »
U'll be fine and get full lock, do the front arch mod, at the worst I think you may get a little rub at the back with a couple of people in when going over big bumps :smiley:
this is all my opinion through experience but I give no guarantee or warranty  :laugh:   :laugh:   :laugh:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #14 on: June 30, 2011, 10:10:36 am »
Course not dude :happy2: Appreciate the info. I simply needed guidance as my driveway is a real bitch so I need more versatility than most who drop.
Thanks chief - awaiting some nice 30mm lowering springs to popup now
Pete
