Author Topic: ENGINE MISFIRE  (Read 2599 times)
Offline jordychris
ENGINE MISFIRE
« on: June 26, 2011, 07:05:09 pm »
Have done a few miles over the weekend Leeds and back then Manchester and back today everyting fine until 60 miles from Newcastle when the car starts to misfire then is ok for a few miles the again misfiring then ok all the way back what can this be.
Re: ENGINE MISFIRE
« Reply #1 on: June 26, 2011, 07:08:18 pm »
Coil pack...
Offline jordychris
Re: ENGINE MISFIRE
« Reply #2 on: June 26, 2011, 07:14:10 pm »
I had 4 coil packs and plugs replaced in Dec 10 could they have failed so early
Offline Marshall
Re: ENGINE MISFIRE
« Reply #3 on: June 26, 2011, 07:17:21 pm »
Unless one of your spark plug holes has water in it?
Are you running with the engine cover on or off?
MISANO RED RS3
Re: ENGINE MISFIRE
« Reply #4 on: June 26, 2011, 07:29:33 pm »
A coil pack can fail at any time!
Probably the best avenue to persue for trobleshooting is to get a fault scan done with vcds. This should point you in the correct direction.
Re: ENGINE MISFIRE
« Reply #5 on: June 26, 2011, 07:30:29 pm »
Should have asked whereabouts are you based?
Offline jordychris
Re: ENGINE MISFIRE
« Reply #6 on: June 26, 2011, 08:03:48 pm »
I am based in newcastle.
Engine cover is on.
The car is a 56 plate i had the coil packs and plugs replaced before the recall will i be able to get new coil packs thru the recall
Re: ENGINE MISFIRE
« Reply #7 on: June 26, 2011, 08:22:54 pm »
No, once the dealer sees that your coilpacks version are not in the recall their responsibilities end.
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: ENGINE MISFIRE
« Reply #8 on: August 15, 2011, 10:27:07 pm »
Would coilpacks be covered under the 60K/3 year warranty?
Re: ENGINE MISFIRE
« Reply #9 on: August 15, 2011, 10:51:00 pm »
It should be if a fault code pointing to it is found  but I'm not 100% certain.
Offline Asa
Re: ENGINE MISFIRE
« Reply #10 on: August 16, 2011, 10:06:21 am »
I have the same symptoms but mines a gt tdi with no coil packs. Has no effect on power it runs great and no fault codes. What could cause this on a diesel?
Re: ENGINE MISFIRE
« Reply #11 on: August 16, 2011, 12:33:02 pm »
I have water in cyl4 hole :( and a misfire. Changed coils (all 4) think I'm going to have to change the plugs again after only 2 - 3000 miles grrrrr
  • MUBster DUBster
Re: ENGINE MISFIRE
« Reply #12 on: August 17, 2011, 09:20:47 pm »
Can't you simply dry out the water?
Re: ENGINE MISFIRE
« Reply #13 on: August 17, 2011, 09:22:26 pm »
Ussually blow it out with an air line when changing the plugs.
