Author Topic: Snow Foam.... which?  (Read 1842 times)
Offline kevinw90
  • GTI!
« on: June 26, 2011, 11:55:03 pm »
Hello,
Looking at getting a snow foam lance and some snow foam.  Not sure which to get tho.  I know alot of its down to people just having their preference but just wanted to see what you guys thought.
Any ideas which I should go for?
  • -Receive: 291
Re: Snow Foam.... which?
« Reply #1 on: June 27, 2011, 02:04:53 am »
Autobrite one is supposed to be good. A lot of people seem to think of snowfoam as allowing them tl do touchless washes, and are then disappointed when the car isn't spotlessly clean.
If you leave used dishes overnight, the food hardens and it's a pain to get off. But if you soal the dishes, most of it comes off more easily. Similar to how you should use snowfoam.
I still follow up a snowfoam with 2BM.
« Reply #2 on: June 27, 2011, 02:06:48 am »
i like the valet pro ph neutral stuff ;)
  • -Receive: 291
« Reply #3 on: June 27, 2011, 02:08:24 am »
I use valetpro too. Why are you up at this hour jay? I though I was the only one with insomnia! :grin:
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #4 on: June 27, 2011, 08:17:19 am »
Valet pro. Our forum's own Keith supplied my snow foam & lance, I've been very happy with both.
Offline SimonBash
  • -Given: 22
« Reply #5 on: June 27, 2011, 12:15:22 pm »
I4 Detailing snow foam has been fine for me.
Autobrite Magiform and Meguiars Hyperwash have good reputations also.
My preferred use is a thorough rinse with the PW then foam, leave it to dwell for a bit then a two bucket wash using the snow foam as extra lubrication.
Works for me anyway :smiley:
Offline scotta
  • Edition 30
« Reply #6 on: June 27, 2011, 12:51:57 pm »
I use Nielsens power foam. Tis good  :happy2:
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #7 on: June 27, 2011, 05:37:07 pm »
Im currently using Autobrite Magifoam and it is very good indeed highly recommended :happy2:
Stealth has said some very good advice there and some'd it up very well about its usage :happy2:
Enjoy your first foaming and dont get too carried away with the foam, neighbours cat/dog for example :rolleye:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: June 27, 2011, 05:48:34 pm »
Another Valet Pro vote here too.
While you're at it get some Bilberry Wheel Cleaner too.  :evilgrin:
Stu...
Offline kevinw90
  • GTI!
« Reply #9 on: June 29, 2011, 09:09:56 pm »
Thanks for eveyones replies!  Ended up buying valet pro ph neutral and did go for some bilberry wheel cleaner while i was at it!
Not sure now wether to use the pressure washer attachment to get all the foam or use the pump sprayer.  Was reading on the valet pro website the pump gives better cleaning but now foam.  Any ideas folks?  Presume most people use a pressure washer.  Just curious?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: June 29, 2011, 09:34:23 pm »
I use a foam attachment for a pressure washer.  I use a hand spray for the wheel cleaner.
Stu...
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #11 on: June 29, 2011, 09:38:22 pm »
Foam lance for the snow foam.
  • -Receive: 291
« Reply #12 on: June 29, 2011, 09:53:35 pm »
To generate foam you need both air an water. Pump sprayer, hosepipe attachments etc only provide water. Get yourself a proper foam lance or IMO there was no point in buying snowfoam!
Offline keith
« Reply #13 on: June 29, 2011, 11:05:04 pm »
VP Ph foam can be used though a foam lance or via pump sprayer and they reckon the later is the better method. I have put loads of stuff through my foam lance, Duragloss901, AS Duet, Megs shampoo+, all sorts of foam. Where i am based I need to use an anti foaming agent when I am finished to disperse the stuff but this was only after I started using a well known foam as it lay for days on end. now use a ph nuetral or a touchless foam depending on what I am doing or my own shampoo.
