Author Topic: Modified steering rack...  (Read 7688 times)
Offline WhiteGTI
  • F-A-S-T
« on: March 18, 2009, 07:02:31 am »
Anyone put/heard of anyone fitting a quicker steering rack onto the GTI?
Something I quite fancy doing really.  8)
2006 E46 BMW M3 - 343hp
Offline SteveS
Re: Modified steering rack...
« Reply #1 on: March 18, 2009, 09:16:00 am »
i find it a bit slow at times...
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #2 on: March 18, 2009, 09:16:16 am »
smaller steering wheel would be massively cheaper? a nice MOMO prehaps?
« Reply #3 on: March 18, 2009, 09:59:42 am »
yo do know you can alter the setting in vag com for the rack
matt a
« Reply #4 on: March 18, 2009, 10:10:45 am »
Like Matt says you can change the resistant settings for the power steering.
Offline SteveS
« Reply #5 on: March 18, 2009, 10:23:47 am »
fk me, i need to use this....
just started another thread if you can use the selectplus switch for vcom
SOLD!! :(
  • -Receive: 453
« Reply #6 on: March 18, 2009, 10:36:16 am »
if vcom is a typo and you really mean vcds (vag-com) then the answer is no.
Offline WhiteGTI
  • F-A-S-T
« Reply #7 on: March 18, 2009, 05:21:12 pm »
Cheers fellas, I'll have a play on vagcom the next time im with someone who has it!!  :happy2:
Offline NEWEY
    • Flickr
« Reply #8 on: March 18, 2009, 05:30:33 pm »
hmmm think ill get aps to have a look at this when its in for its service soon
TSR big turbo mk5 golf gti
Offline WhiteGTI
  • F-A-S-T
« Reply #9 on: March 22, 2009, 08:38:32 pm »
Where abouts in VCDS is this setting??
  • -Receive: 453
« Reply #10 on: March 22, 2009, 10:48:18 pm »
Try this:
[Select]
[44 - Steering Assist] (from Chassis tab)
[Recode - 07]
Take note of the value which is in the form 0001x1 where x is the weight setting, eg 000121
If x is set to 1, it will be very light, if it is set to 5 it will be heavy
Replace the number with the required weight, eg 000151
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #11 on: March 22, 2009, 10:53:35 pm »
cool to know  :happy2:
whats the std default setting from the factory ?
Red ED35 5dr DSG
BLOG | BUILD
  • -Receive: 453
« Reply #12 on: March 22, 2009, 11:00:18 pm »
iirc it's 2
« Last Edit: March 22, 2009, 11:24:11 pm by bacillus »
Offline WhiteGTI
  • F-A-S-T
« Reply #13 on: March 23, 2009, 02:09:10 pm »
Try this:
[Select]
[Recode - 07]
Thanks as always Bacillus. Ok, so as I understand this, this setting is to alter the weighting/resistance of the power steering. How is this going to make the car react as if it had a quicker steering rack? By that I mean that I am looking for less steering wheel turning force needed to turn the car to the required point.  :smiley:
  • -Receive: 453
« Reply #14 on: March 23, 2009, 07:52:41 pm »
Not sure what you mean by a quicker rack with this tinkering as all it does is increase or decrease the weighing of the steering.
For a quicker rack you will need to change the gearing ratio on the rack itself.
