Author Topic: Low oil pressure  (Read 2142 times)
bailey
Low oil pressure
« on: June 27, 2011, 02:15:19 pm »
Hey, i have a MK5 gti, done 130 thou miles!! but always been a good runner, got FSH and all that, i was recently driving a 200 mile journey when my Oil light came on, I heard 3 beeps and a red oil light came on and the dash said stop low oil pressure! i was thinkin maybe a faulty pressure switch, but there is no trouble codes, so maybe a dodgy oil pump? or blocked pick up pipe or strainer? any one else had this problem? would be a lot of help to share your knowlege, much appreciated..bailey
Re: Low oil pressure
« Reply #1 on: June 27, 2011, 02:59:23 pm »
maybe a silly question but you have checked the oil level as well
Offline Matjazz
    • EUworld
« Reply #2 on: June 27, 2011, 03:31:25 pm »
Hi mate! Couse of that I sold my GTI... Read my treath
http://www.mk5golfgti.co.uk/forum/index.php/topic,25618.msg332673.html#msg332673
My advise... Screw off buton for oil change (where you replace, add oil into the engine) And check with your finger if there is any old/dirt oil stick to the engine. I got cca 1cm of old oil all ower the engine... If that is it you are looking some expensive ways for clean these sh*t off...
bailey
« Reply #3 on: June 27, 2011, 04:13:41 pm »
yea mate ive checked the oil level its fine, i drain the oil the oil looks perfectly fine, im half way through removing the sump to check the pump and pick up pipe, ill check that thread cheers buddy..heard the pumps are common for goin on these? cheers for replying
