Author Topic: revo select plus switch and vag-com?  (Read 8688 times)
Offline SteveS
« on: March 18, 2009, 10:22:40 am »
Anyone know if they will work together. some places on google search say yes... wondered if anyone here actually had?
I have emailed revo to ask them too..
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Re: revo select plus switch and vag-com?
« Reply #1 on: March 18, 2009, 10:40:01 am »
Not entirely sure what the question is. Yes they will work together but not sure what you mean by together. :confused:
The REVO Select switch alters your REVO remap settings and VAG-COM(VCDS) alters your car settings.
VCDS is also a very useful diagnostic tool.
Offline SteveS
« Reply #2 on: March 18, 2009, 10:48:24 am »
yes yes, but can you use vcom WITH the switch ..
SOLD!! :(
Offline gazbutS3
« Reply #3 on: March 18, 2009, 10:50:27 am »
why would you want to, in what way, you change the settings using your switch at standstill, then take some live reading with VAGcom :happy2:
Offline SteveS
« Reply #4 on: March 18, 2009, 10:54:52 am »
i want to, so i dont have to buy another cable... just to see logs...
SOLD!! :(
« Reply #5 on: March 18, 2009, 12:12:41 pm »
I think I understand now.
To use VCDS on a MK5 you will need a CAN capable cable. Check here www.ross-tech.com, a micro-can is sufficient. :happy2:
The REVO select switch on the end of a USB lead is not enough.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: March 18, 2009, 12:13:22 pm »
VCDS (VAG-COM) software is not free, the registration is built into the cable as a sort of dongle.
Stu...
Offline SteveS
« Reply #7 on: March 18, 2009, 12:33:51 pm »
darn
SOLD!! :(
Offline SteveS
« Reply #8 on: March 18, 2009, 02:25:58 pm »
the older version 409 or close... says it works with third party cables. so they cant have the "registration" built in..
SOLD!! :(
« Reply #9 on: March 18, 2009, 03:52:57 pm »
The 409 version will work with 3rd party ebay cables but not with a CAN-Bus based car.
It MUST be the latest s/w version plus either a Micro CAN or Hex-CAN-USB cable.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #10 on: March 18, 2009, 07:19:13 pm »
http://www.ross-tech.com/vag-com/faq_2.html#2.2
Quote
2.2  What's the difference between the Shareware version and the fully registered version?
All of our Current Interfaces  have Activation built-in, so VAG-COM will always be Fully Registered/Activated. If you have an older Interface without built-in Activation, or have purchased an Interface somewhere other than Ross-Tech, VAG-COM will operate in Shareware mode until it is Activated. The differences between Shareware and fully registered/activated versions are listed near the bottom of each function page in the Online Demo / Manual and in the VAG-COM Function Chart.
Stu...
Offline SteveS
« Reply #11 on: March 18, 2009, 07:28:41 pm »
yea saw that.
oh well, have to find someone to check for me :)
SOLD!! :(
