Author Topic: bad idle  (Read 1757 times)
Offline critter
bad idle
« on: June 28, 2011, 11:43:42 pm »
    Any ideas before i book it in to the dealers, car just started idling badly and overrunning on switch of.
     it was low on oil,but no warning light on, and it went to the dealers to have coil packs done last week.
    any help
                Thanks Chris
Re: bad idle
« Reply #1 on: June 29, 2011, 02:44:31 pm »
I would check for a vacuum leak.
Offline critter
Re: bad idle
« Reply #2 on: June 29, 2011, 10:21:40 pm »
    Will do,was up till 1 last night looking at old posts and it seems to happen quite a lot.
    Found  a lot of info so just need  time to check everything.
Offline JackP
Re: bad idle
« Reply #3 on: June 30, 2011, 02:00:50 pm »
im sending mine into vw for diagnostics, it could be sat in a garage all year trying to find it may aswell pinpoint it then i can sort it
Offline johnboy07
Re: bad idle
« Reply #4 on: June 30, 2011, 04:21:07 pm »
Had the same kind of problem on mine and turned out to be the pcv so bought a revamp kit from dubtek and its alot better and smoother to drive  :happy2:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline mattchaps
Re: bad idle
« Reply #5 on: June 30, 2011, 04:23:14 pm »
Mine has the same issue, have changed PCV, coils and plugs and still no change. Just haven't been able to get it to a decent garage for a scan.
Let us know what yours comes up with :happy2:
MkIV R32 Turbo - Gone but not forgotten -  Click here
MkV GTI - Arrived
Offline critter
Re: bad idle
« Reply #6 on: July 01, 2011, 08:49:33 pm »
      It went in to main dealers today, it turned out to be the pcv, although i have not picked it up and driven it yet so fingers crossed thats the end of it.
