Author Topic: RVC and MDI at the same time?  (Read 1339 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« on: June 29, 2011, 06:47:52 pm »
A friend of mine has the MDI fitted and he states that it uses the same plug as the RVC.
Is it possible to be running both??  :drinking:
Over the top mod list ;o)
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: RVC and MDI at the same time?
« Reply #1 on: June 29, 2011, 07:40:21 pm »
Yes it is as I have it on mine, there is what is called a quad lock connector on the back of the unit (see link below)
http://www.my-gti.com/529/volkswagen-rns-510-pin-assignments
Plus there is an additional connector for the reverse camera. Hope this helps.  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: June 29, 2011, 07:41:54 pm »
Edit - Beaten to it  :smiley:
All the MDI kits I have seen use the CD changer audio in, can bus and power from the quadlock and not the video in port.
I fitted an RVC and MDI to Moschops car with no problems  :happy2:
  • -Given: 243
  • -Receive: 154
« Reply #3 on: June 29, 2011, 07:58:14 pm »
Cheers fellas, i'll pas the info on  :notworthy:
  • -Given: 243
  • -Receive: 154
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: June 29, 2011, 09:49:32 pm »
See the note at the end of the page
Quote
or retrofitting into VW vehicles with factory fitted rear view cam "Low" (Golf 6, Scirocco) item 37611 will be needed in addition
