Author Topic: Exhaust light on after stage 2 ?? Help with fault codes please...  (Read 25582 times)
Offline heavyd
  • -Receive: 29
Re: Exhaust light on after stage 2 ?? Help with fault codes please...
« Reply #135 on: February 09, 2012, 05:27:26 pm »
Oh well, thought it was all too good to be true.....
I have this code on, MIL ON.
I saw the code last week but cleared it off as there was no MIL on the dash. Well its back again. It was only a year ago I went through this with the stage 2+ Revo that I got a refund on. Now the stage 2 file I had loaded on is doing the same :fighting:
Thursday,09,February,2012,16:59:45:05205
VCDS Version: Release 11.11.1
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 L    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 040300031C070160
            Work Shop Code: WSC 80176 538 403142
                      VCID: 2F43C984BE066CC
1 Fault Found:
008584 - Bank 1; System too Rich at Idle
               P2188 - 008 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 76620 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:31:38
             Freeze Frame:
                    RPM: 756 /min
                    Load: 22.7 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 14.351 V
code from last week
Saturday,04,February,2012,13:22:10:05205
1 Fault Found:
               P2188 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 76303 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:49:41
             Freeze Frame:
                    RPM: 725 /min
                    Load: 27.0 %
                    Speed: 4.0 km/h
                    Temperature: 83.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.081 V
Offline Gti_Mad
« Reply #136 on: February 09, 2012, 05:42:33 pm »
sh*t sorry 2hear your havion problems again dude, not havin much luck are ya mate  :sad1:
i reckon you should try the apr map if anything seen as you've had nothing but problems with every1 else
Saintsteve
« Reply #137 on: February 09, 2012, 05:42:59 pm »
What intake are you running?
Offline heavyd
  • -Receive: 29
« Reply #138 on: February 09, 2012, 05:48:17 pm »
ITG intake.
Its only ever Revo software I have this problem on :stupid:
I've had every other companies software on :signLOL: and it only appears with Revo, same as last year :fighting:
« Reply #139 on: February 09, 2012, 05:58:18 pm »
ITG intake.
When you trying APR Dom  :popcornsoda:
Saintsteve
« Reply #140 on: February 09, 2012, 06:22:57 pm »
ITG intake.
Ditch Revo then  :signLOL:
I'd try running a panel filter to see if the fault re occurs personally
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=9uq5v7bsj25r7rqk94ghfr75u4&/topic,19740.0.html
« Reply #141 on: February 14, 2012, 01:05:48 am »
heavyd... who installed the REVO software?
Thats the exact same fault code i had, when i had the wrong map file installed.
Offline heavyd
  • -Receive: 29
« Reply #142 on: February 14, 2012, 02:32:26 am »
I had it re-flashed today by PDT. it had version 9 on, and now has version 10b  :confused:
Will know in a couple of days if it has worked or not :happy2:
Offline heavyd
  • -Receive: 29
« Reply #143 on: February 18, 2012, 03:35:50 pm »
Well I've done a fair few miles now, no faults showing on vcds, so looks like the update worked. Thanks to PDT yet again :drinking:
