Author Topic: Exhaust light on after stage 2 ?? Help with fault codes please...  (Read 25627 times)
Offline Gti_Mad
Re: Exhaust light on after stage 2 ??
« Reply #30 on: July 02, 2011, 04:48:31 pm »
Hi Mandy have you had your car scanned yet????
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #31 on: July 02, 2011, 06:37:59 pm »
Come down a get one of my 3.00" TBE's with the 125mm 100 cell m/sport cat and kill that sucker  :fighting:
Offline chungster
« Reply #32 on: July 02, 2011, 06:40:52 pm »
Was a task getting to her go to Leicester for GTI Inters let alone the north west Nigel  :signLOL:
Saint Steve
« Reply #33 on: July 02, 2011, 06:49:59 pm »
vcds scan is being planned in due course....
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #34 on: July 02, 2011, 07:45:13 pm »
Don't worry
 contrary to a popular misconception the M6 is tarmac'd above Spaghetti Junction - they ripped up the cobbles a few years back  :signLOL:
Offline baldwined30
« Reply #35 on: July 03, 2011, 08:53:47 am »
I had this problem with stage 2 Bluefin!! was really annoying! sorted now as they turn off the exhaust light! Wish i had of gone revo though!!!
Ed30
Offline vRS_Pagey
  • -Receive: 59
« Reply #36 on: July 04, 2011, 04:19:20 pm »
Cheers Domt,
I have got a CAI and intercooler already, been told i do not need a exhaust aslong as i uprate the downpipe.
Correct, all the gains come from a larger bore DP with no precat and either a 200/100 cell sport cat or decat due to lower temperature EGT's, beyond the cat will gain an extra 1-2hp if your lucky.   :happy2:
Offline alexperkins
  • -Receive: 98
« Reply #37 on: July 04, 2011, 05:25:00 pm »
I would change to a Rev D valve in any case. It can handle a much higher boost pressure so its definately worth it
Offline Kiwi
« Reply #38 on: July 04, 2011, 07:55:11 pm »
Has that been proven ??
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=1q0ue6p08eq795jh4tcnidgn7o&/topic,19740.0.html
« Reply #39 on: July 04, 2011, 08:11:09 pm »
TBH i think its pretty poor that REVO flashed your car, and your having to faff around getting it sorted out. I hope they will rectify it gratis!
Saint Steve
« Reply #40 on: July 04, 2011, 08:21:38 pm »
Ok, totally off the point but you need to update your sig.  :smiley:
Lol, you're right, I do. It's more stage 1.5 at the mo, not quite at stage 2 yet!  :laugh:
Hi Dawain, no not yet. Steve  :scared: has offered to scan the car somewhen soon though...   :scared:
No it wasn't Lee, I willingly went...  :innocent:
I think the next step will be a trip to JKM to sort the remap out, currently thinking about going for the ITG maxogen and will probably get an Evoms engine cover. I'm thinking I should change my DV to the revision D too, although JKM said it looked fine last time, but now it's stage 2, might be worthwhile.
:confused:
« Last Edit: July 04, 2011, 08:24:15 pm by Saint Steve »
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #41 on: July 11, 2011, 10:14:49 am »
Steve, I've pm'd you.
Saint Steve
« Reply #42 on: July 11, 2011, 06:19:00 pm »
Scanned Mandys car today, and its also got issues with rich idle condition, sending on the exhaust emmisions light on since having Revo stage 2 installed by Revo.
From what i can see , it looks like her stock oem filter is to blame for the issue.
I feel Revo have no checked her mods prior to setting her Revo up for her at inters, and not checking what mods the car was fitted with before installing their settings.
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI     0010
Revision: 5BH16---    Serial number: VWX7Z0GD3NB7VE
Coding: 040300031C070160
Shop #: WSC 12598 027 411270
VCID: 375B18083FDD
1 Fault Found:
008584 - Bank 1; System too Rich at Idle
P2188 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 2
Mileage: 67096 km
Time Indication: 0
Date: 2000.00.00
Time: 10:35:05
Freeze Frame:
RPM: 782 /min
Load: 27.0 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 27.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
She also has this fault which wont clear on vcds, although not causing an issue with the car atm, but keeps re-appearing as soon as its cleared..
Address 16: Steering wheel       Labels: 1K0-953-549-MY8.lbl
Control Module Part Number: 1K0 953 549 BG    HW: 1K0 953 549 BG
Component and/or Version: J0527           051 0100
Software Coding: 0012122
Work Shop Code: WSC 01279 785 00200
Additional Info: XXXXXXXXXXX E0221           002 0010
Additional Info: Geraet 00200
VCID: 78D9DB347243
4 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Faulty ignition switch perhaps? any help would be great. :happy2:
Oh and hope youve had a lovelly Birthday today Mandy!!!  :laugh:
Offline heavyd
  • -Receive: 29
« Reply #43 on: July 11, 2011, 07:49:29 pm »
That rich on idle seems to  be getting popular ith revo, I couldn't get rid of it. Try and get in touch with Nathan on here, he was the last person to get the code, and has also bought a few bits to try and solve it  :happy2:
« Reply #44 on: July 11, 2011, 09:05:20 pm »
Don't worry about the ignition switch errors seen it a few times and I guess it's because you got the ignition on. You can't clear it either.  :wink:
Regarding the too rich at idle. I don't think it's the air filter unless it's full of leaves. I would check the Revo settings first and then look to wind them down to something like 6-4-9.  :smiley:
